Author Topic: Billet blocks....who will pay...pics added 9/7/09...10/24....2/10  (Read 194994 times)
Offline Doctor_D
Re: Billet blocks....who will pay...pics added 9/7/09...10/24....2/10
« Reply #625 on: September 23, 2013, 12:54:28 PM »
Someone needs to get one of these on a dyno.  Please don't make me have to build a 125-x12 cammed, 1-liter CB just to see what can be done with these things.
Take care,
David
1978 CX500
1971 Norton Commando
Offline Tintop
« Reply #626 on: October 04, 2013, 08:47:43 AM »
Mike, way back on page 4 (I think) you originally indicated that the blocks would be available with bore sizing down to suit 836 (65mm??).  Is that still the case?
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #627 on: October 05, 2013, 05:08:48 AM »
That would have to take place during the manufacturing process Brian. Unfortunately the last batch is done and I have ave about 15 cylinders left....no plans for making more in the near future.
Offline Tintop
« Reply #628 on: October 05, 2013, 12:44:16 PM »
That's kind of what I thought Mike, but figured I'd ask.  Two questions then...what is the minimum piston size the ones you have been bored for? /  Could one of the ones you have be remachined & sleeved to take a smaller piston??   Realize the second one kind of defeats the heat loss benefit, but the bigger fin area would be an improvement over a stock barrel.
77 CB550 Cafe build
« Reply #629 on: October 06, 2013, 05:19:10 PM »
70mm is the minimum. A stock sleeve is to small for the current bore.
Offline Tintop
« Reply #630 on: October 06, 2013, 07:59:13 PM »
Thanks for the reply Mike.  I was thinking of the CycleX, or Dynoman 915 kit with sleeves.
77 CB550 Cafe build
« Reply #631 on: October 07, 2013, 07:41:53 AM »
What's the OD of the 915 sleeve. I can't remember off hand but it would probably work...just mill off the  bore extensions on the bottom of the cylinder and bore a bit for the sleeve. You would certainly have plenty of meat in between the cylinders. ;D
Offline Tintop
« Reply #632 on: October 07, 2013, 10:53:20 AM »
I'll get the information and we can go from there Mike.
77 CB550 Cafe build
« Reply #633 on: October 07, 2013, 01:45:04 PM »
Sounds like a plan. ;)
Offline johno
« Reply #634 on: October 26, 2013, 06:25:37 PM »
Hi Mike,
I know this info will be on the thread somewhere but its a bloody long thread so being a lazy arsed Sunday afternoon I'll ask instead of looking.
What heads are the barrels set up to suit K or late F ? or knowing you... adaptable for both ?
Dont get your hopes up yet but this competative spirit between the Suzuki waterbottle record holder is reaching a new high level, paying the crap out of each other on DLRA website and I'm thinking stuff the class business ,   its waterbottle versus CB honda and If I cant make it run 150MPH in 750 trim I might drop on one of your barrels to run more than 150 MPH and give Finny la Suzuki man the bird when I pull back into the pits.
Mans got to have some pride, its what makes it fun.  ;) ;D ;D        let me know re the heads Mike.
cheers johno
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
Offline cbornotcb
    • Photobucket link
« Reply #635 on: October 27, 2013, 02:15:00 AM »
Ha Ha Johno, you're sounding like me when I was dong the postie bike thing, The only "postie" left on the Postie, was the steering head, forks, and kick starter, and it jumped out of 125, and into 175 capacity breaks
Its still waiting in the bleaches, chock full of new OEM and Carillo bits (It earned a record of 87 mph with GayBay goodies innitt)
It's still "MY Postie"
Tiny
  • Moderator
« Reply #636 on: October 27, 2013, 07:46:03 AM »
That's my mate Tiny, give em the finger mate. Haha.
Sam.
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #637 on: October 27, 2013, 10:13:29 AM »
I have a used set of 888cc sleeves, let me know if you have any interest
Offline pencil9
« Reply #638 on: November 08, 2013, 04:19:12 PM »
I'll hazard a guess.....to get the CNC specs you need to reproduce it in metal??
« Reply #639 on: November 18, 2016, 12:24:23 PM »
Thread needs more .... ;)
Billet block in my garage thanks to Mike!
The entire block has harder surface than I expected. Sleeves/bores have a steelish look and feel.   No swampy soft alu here!
71.25mm JE pistons, Dynoman 1000cc, crowns something between the 10.5:1 to 12.5:1 since they are adapted for 24.4cc chambers to ensure 10.5:1
My first plan was to use an old block to bore more and insert sleeves for these pistons. Eventual oil leak, weld job for air wents between 1-2 and 3-4 made billet block to a simple choice. The added initial cost will probably end up in less rework and no problems later on. (the old cyl might get the big bore sleeves anyway after weld. spares are good)
I have to do the case manually since one case stud is stucked and not possible to leave for professional machine shop. Tried heat and real excessive force to remove it. I must have used Loctite 272.
Will grind this weekend. Base gasket help to mark where to remove alu from top case.
K Head has 34mm in valves, cam will be DP315. APE ultra crank w carillos, undercutted gears, primary hub got new rubbers last spring.
Exhaust HM300 replicas. Carbs Mikuni TMR32
It will be interesting to take it to Dyno when assembled and carbs jetted correctly. I'll check with WegoIII A/F gauge, sniffer in pipe by pipe to make sure that it will be correct. Dyno 6 months from now...?
Grind case and file piston ring ends to correct gap this weekend. Pics below with pistons for display, nr 4 on cyl 1. I've marked them all after I have checked the Dynoman instruction and verified with head so the cut outs will line up with the valves. Verify that all have same weight.
 I look forward to verify piston/head/valves/squish with clay....
edit: added one pic
« Last Edit: November 18, 2016, 01:31:48 PM by PeWe »
« Reply #640 on: November 18, 2016, 01:25:03 PM »
Should make for a good package.  8)
« Reply #641 on: November 18, 2016, 01:36:24 PM »
Yes, I'm rather sure it will improve :) The clean design of the cylinder block in Laverda tripple style demands clean head, fresh paint on cases and all other details to match.
« Reply #642 on: November 18, 2016, 02:22:15 PM »
 ;) ;D
Offline Bill/BentON Racing
    • BentON Racing
« Reply #643 on: November 18, 2016, 04:40:22 PM »
And strong as can be wrist pins, lol, Bill
BentON Racing Website
BentON Racing Facebook
« Reply #644 on: November 19, 2016, 06:07:40 AM »
Absolutely. It does give the engine a very beefy look. ;)
« Reply #645 on: November 19, 2016, 01:13:38 PM »
Like Japauto 1000 if comparing with other Honda but more beautiful design. The metal has a very nice surface as mentioned earlier. Alu is anodized?
Grinded case with base gasket and marker pen as guide. Cylinder almost fit, a few spots need more grinding. I'll wrap on a turn of paper tape around the sleeves so the marks will guide were to grind more and avoid grind too much were not needed. The cyl studs must be glued next time for max strenght I guess.
Must fix the case surface with 400 paper as I did to the head. Viton steel base gasket can accept very thin layer of sealer? On case side only if not abolutely scratch free.
Grinded hole thru the case on alternator side today! Big bore makes Big holes! ;)
EDIT: I'll double check the wrist pins delivered with the JE pistons.
My old RC forged 836 pistons with teflon pucks have lighter pins, thinner...
« Last Edit: November 19, 2016, 01:26:15 PM by PeWe »
« Reply #646 on: November 19, 2016, 04:59:41 PM »
Watch those lighter pins, Bill Benton just destroyed a new engine, it was the light weight pin that let go....
« Reply #647 on: November 20, 2016, 08:34:09 AM »
Bead blasted with fine bead Per
« Reply #648 on: November 20, 2016, 12:58:27 PM »
Ok, glass beads? It's usally more harsh and glittery after that. Billet block with the 77mm sleeves entered the upper case today ;) I have to remove the leftovers of the lands between 1-2 and 3-4, right?
Hole thru the case on 1 into alternator side need to be widened a little to remove the too thin walls, right?
I guess YES on all when I cannot see any other way and I saw the holes coming before the correct diameters were reached. I have earlier seen photos on upper case for big bore after machining. I could not find them for comparison.
« Reply #649 on: December 11, 2016, 01:20:52 PM »
I have the cylinder on with pistons inside, no rings. Test assembly without studs so far, dowel pins in to guide cylinder correct on case and head on cylinder.
Will clay piston tops, mount cam and set it close to earlier. No exact timing.
Will check that valves corresponds to the piston pockets and check squish to head flat area as well as inside chambers.
This is a really FAT bore that will be notified when parked! I do not need to twist the throttle to show off  ;D
Head surface is painted and do not match exactly. Should I paint the billet block too with same rattle can motor paint as head and case?
Might keep dirt off easier?
« Last Edit: December 11, 2016, 01:26:06 PM by PeWe »
