Author Topic: Swingarm shock cushion question  (Read 1007 times)
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« on: April 09, 2009, 07:12:43 AM »
I've taken apart my swing arm for powder coating but not the 'rear cushion under rubber cush' that the rear shocks connect to. Are these real bushings I need to preserve? Do I remove them for painting. If so how do they come out (and go back in)
Offline voxonda
Re: Swingarm shock cushion question
« Reply #1 on: April 09, 2009, 07:17:32 AM »
Take them out, works with a piece of round bar. New one's costs close to nothing, or push the old one's in with a vise or a bolt thru with nut and big(ger) rings..
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #2 on: April 09, 2009, 07:21:37 AM »
Voxonda is right.
Just press them out and reuse if you wish.
I used a couple of sockets and a vise to re & re mine.
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #3 on: April 09, 2009, 07:23:30 AM »
if you're getting it powder coated, the powder wont stick to the bushing anyways. throw some tape on there and get it done.
Offline phillip56
« Reply #4 on: April 09, 2009, 08:08:33 AM »
I'd remove then.  When they coated the metal ring around the outer part of the bushing will attach the powder and if you have to change them at a later day you'll mess up the coating.  Just be careful when you push them out to be on the outer ring not the rubber.  The rubber will separate for the ring (did it once  >:().
Offline mycb750k6
  • Rocketman
« Reply #5 on: April 09, 2009, 08:45:10 AM »
OK I got it guys, thanks. You say these are easy to come by and not expensive. Where can I get them? I checked David Silver already.
  • Like a well oiled
    • Undead Asphalt
« Reply #6 on: April 09, 2009, 09:46:07 AM »
I agree, pull em out, but maybe put some tape in the inside of that loop-
   I would think the tolerances would change on that pressed in bushing and you'd mess up the powder coat pushing it in.
  • Like a well oiled
    • Undead Asphalt
« Reply #7 on: April 09, 2009, 12:10:31 PM »
oh yeah I forgot about the oven temps.
