After painting the engine, it's time to start assembly.
Question regarding the gear selector:
Does it matter how the gear selector is rotated? If all the forks are in their correct locations, left, center and right along the notches in the gear selector, everything should be good correct?
Rotating the gears by hand, and selecting gears by rotating the gear selector by hand, everything seems to be smooth, but I cant seem to find neutral. When in neutral, the sprocket shaft should NOT spin correct?
![](http://img155.imageshack.us/img155/8129/dsc01380w.jpg)
![](http://img183.imageshack.us/img183/9286/dsc01381.jpg)
![](http://img17.imageshack.us/img17/3381/dsc01384c.jpg)
![](http://img513.imageshack.us/img513/6906/dsc01383q.jpg)
![](http://img401.imageshack.us/img401/9382/dsc01382v.jpg)
Another question regarding the oil seal on the main shaft on the clutch side, i got an entire set of new oil seals but this new seal doesnt have the rigid metal plate in it, just really flimsy rubber. Should i try and locate an OEM oil seal, or will this Sudco seal work just fine? Anyone have experience with these?
Original seal on left, new replacement seal on right:
![](http://img142.imageshack.us/img142/7083/dsc01385s.jpg)
Pretty Flimsy:
![](http://img155.imageshack.us/img155/9467/dsc01389k.jpg)
![](http://img155.imageshack.us/img155/6946/dsc01388y.jpg)
Thanks to everyone for helping me out with this first rebuild! Hopefully this will help others in their hesitancy for tackling a rebuild.
