Author Topic: Yikes the missus bike flies!!  (Read 15037 times)
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
Re: Yikes the missus bike flies!!
« Reply #100 on: January 26, 2010, 09:52:19 AM »
That should work no problem on the twin.  I had to flip the goldwing at the coils when it happened to me.
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
Offline Hush
« Reply #101 on: January 26, 2010, 09:17:31 PM »
I've had a think about this and it would work but only for the left side cylinder as both cylinders were timed off the left side timing mark
Offline Hush
« Reply #102 on: January 27, 2010, 12:46:28 AM »
Oh pox....it still wont start!
I've got a horrible feeling I'm gonna be up for a new motor. :(
Offline clarkjh
  • Expert? If only.
« Reply #103 on: January 27, 2010, 02:57:14 AM »
I've got some GX400 parts laying around, I'll see if I can find them.  I do have the engine as well but it was left in the weather before I got it and was stuck solid.  I should have the electrics for the ignition some where.
James
SOHC/4 #3328
Offline Hush
« Reply #104 on: January 28, 2010, 02:35:04 AM »
Freighting an engine might be a bit prohibitive mate. ;D
The pickups and rotor might be handy.
Offline clarkjh
  • Expert? If only.
« Reply #105 on: January 28, 2010, 07:42:39 AM »
I bet the $$ the engine would cost would be.  I sent one of my small bowls to Queens Land in Aussie and it was $70 CDN just for postage.
I see if I can dig out the electrics over the weekend.
James
SOHC/4 #3328
« Reply #106 on: January 28, 2010, 09:10:36 AM »
If it stopped suddenly i would suspect more the ignition circuit than anything else mate
Offline Hush
« Reply #107 on: January 29, 2010, 01:04:49 AM »
Yeah the armature thing that goes over the stator kept flying off and I suspect it took out the stator wiring as a quick short and that killed the bike.
I was going to do the head gasket anyway in the winter so this just sped things up.
Offline Hush
« Reply #108 on: February 01, 2010, 01:08:18 AM »
Have retimed the bike, reset the the cams and chain and timing marks etc, still doesn't want to start so suspect I've screwed up the points area somehow, gonna remove the whole points plate and check it over then reset it all again...........grrrrrrrrrrrrrrrrr. :(
Offline scunny
  • don't call me expert
« Reply #109 on: February 01, 2010, 09:39:23 AM »
get back in the garage Hush. I bet it's something simple
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline Frankenkit
  • Industrial Strength
« Reply #110 on: February 01, 2010, 12:28:43 PM »
...or take a little break from it and ponder for awhile.
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline Hush
« Reply #111 on: February 04, 2010, 08:28:55 PM »
have been doing just that Kit, when I finish work I just decide not to go near the shed some nights.
I did remove the whole points system and replace all the wee adjusting screws as they had all had their tiny little it ti bit ti threads TOTALLY MANGLED BY SOME CROMANGON!!! but enough about my lack of finesse with a screwdriver. ;D
Jaffa's bike is one of those anomalies, it is part way between the era when the GSX400 had it's points replaced with PEI (CDI) and the cam chain system was altered for whatever reason.
So she has the modern cam set-up but the older points system, I need to refer to the 81 manual I bought for the points and then rush inside to check the manual I downloaded for the cams...most vexing. >:(
Anyhow while I dither, Jaffa has been getting on with the paint job, God this thing looks girlie! :D
« Last Edit: February 04, 2010, 08:41:58 PM by Hush »
Offline Hush
« Reply #112 on: February 07, 2010, 06:38:50 PM »
OK I'll admit it, I'm stumped...it is so tuned it should start!
I'm gonna get an old mate from my teenage riding years who like me still potters around with bikes to give me a hand, maybe he can see what I am doing wrong?
Offline scunny
« Reply #113 on: February 08, 2010, 10:31:56 AM »
good idea Hush, sometimes we can overlook the obvious
            VTR1000F3
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
Offline Hush
« Reply #114 on: February 12, 2010, 01:50:08 AM »
Arrrghhh, you know the drill, fix one thing and another breaks!!!
That horrible noise seems to be coming from the starter motor which is now not turning the donkey over, took it apart and the brass bush in the end is all knocked about...will require renewing.
Hopefully once I've climbed that mountain the damn bike will fire up!
