This is totally my portion of the thread so I will attempt to clarify.
I have a 750F ('76). It came with wire wheels and rear disk and sprocket mounted on a cushioned drive that sits in the wheel with substantial rubber padding.
I changed to S-D cast wheels in '78. This means the rear sprocket is now completely rigid being mounted on studs that go directly into the wheel.
So each time I shift gears, the chain gets a jolt that is no longer absorbed by the factory rubber cushions in the wheel assembly. In my case the result is a chain that is in need of frequent tensioning. I do a pretty good job of lubing it. I also drive rather reasonably (old age and insurance costs do that) and not in the rain. I use 530 chains; not always of the highest quality.
As I said earlier , maybe its my shifting or something but I do poorly on chains. If I modify the S-D set up and things continue, I have to assume its me.
By way of comparision, in the 80s I used to road race a 1979 DOHC 750 with the stock Comstars and which include the same kind of factory cushioned drive. In three seasons of that beating, I never had to change the chain and kept using it for a long time after the bike went back to being street.
I have a Lester 750F rear wheel and I note that they machined pockets to allow use of the factory cush drive for the sprocket assembly. Dont know anything about Morris.
So if you are having real good luck with S-D wheels, I need to know what chain you buy , how you maintain it and so on, since you are doing something alot better than I am!
You got 10000 miles out of two chains; that's about what I am getting.
thanks!
John
