Author Topic: Oil Leak from Cam Chain Tensioner Screw?  (Read 1346 times)
Offline RainyRider
  • 1976 CB550K2
« on: April 10, 2009, 04:58:48 PM »
Hello wise gurus of the SOHC4 forum...
Bike: 1976 CB550k, 16kmi
I think I have oil leaking from my cam chain tensioner screw/nut. After running a while, it appears drippy and oil is seeping from that area along the lowest fin then drips down over the left side case, and sometimes splashes onto the shift lever rubber and my boot. ANyone else seen this? I've loosened it, cleaned it, then tightened it (in the appropriate manner) to no avail.
Thanks
RainyRider
Re: Oil Leak from Cam Chain Tensioner Screw?
« Reply #1 on: April 10, 2009, 05:16:24 PM »
There is an o-ring under the flat washer, sounds like the culprit.
Offline RainyRider
  • 1976 CB550K2
« Reply #2 on: April 10, 2009, 09:11:44 PM »
Thanks for helping a noob! Just picked it up at the shop. Now, can I install it? Just cram it in there behind the washer? should I fish the old one out somehow?
« Reply #3 on: April 11, 2009, 12:52:36 AM »
Yes you must remove anything in there first
Offline RainyRider
  • 1976 CB550K2
« Reply #4 on: April 11, 2009, 01:02:37 AM »
Thanks.
Just did it. No big whoop with a little sharp screwdriver to dig out that 33-year-old rubber.
~RR
