Author Topic: how much power did the 350 twins make?  (Read 11086 times)
fuzzybutt
« on: April 12, 2009, 07:37:02 AM »
i was wondering how much horsepower the 350 twins made, 71/72 specifically.
Offline rchrdms
  • Honda CL350 Twin '72
    • Richard F Meese
Re: how much power did the 350 twins make?
« Reply #1 on: April 12, 2009, 09:59:25 AM »
Hi,
29.7 horsepower at 8,000 rpm.
That's for the CL 350 Twin for all years.
I used the formula in the Clymer manual: horsepower = rpm x torque / 5,252.
For some reason they give you the numbers and make you do the math. I hope this is right and my figuring didn't go wrong.
Rick
Offline HondanutRider
« Reply #2 on: April 13, 2009, 08:36:59 AM »
There is a direct relationship between torque and horsepower at any given RPM, as your formula calculates.  However, most engines produce a maximum torque at a lower RPM than where the maximum horsepower is generated.  If you calculated 29.7 as the horsepower from the maximum generated torque, then the engine should still be producing a bit more horsepower at a higher RPM.
From the figures originally quoted by Honda in their sales literature for the 350 twin, dated February 1968, they claimed maximum horsepower and torque as follows: 36 HP at 10,500rpm and 18.5 lb-ft torque at 9,500rpm.  I always believed these figures were exaggerated, and what you calculated/quoted, although lower, seems more realistic.
Offline lordmoonpie
    • Moonpie
« Reply #3 on: April 15, 2009, 05:12:37 AM »
By the time I sold my '72 CB350 K4 it was doing 49bhp at the back wheel....and went like stink!  ;D
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline tbpmusic
« Reply #4 on: April 15, 2009, 01:26:14 PM »
Holy cow !!!!
How did you do that ??!!
Bill Lane
Offline myhondas
  • Not really such a
« Reply #5 on: April 15, 2009, 02:11:45 PM »
posted this in another thread, but will add here also...
http://www.motorera.com/honda/index.htm
ray#?
1974 CB 750 K4 SHOWROOM
1965 C100 CUB 50 (PIT BIKE)
1996 VF 750 CD daily rider
SOHC# 5105 11228
Offline 333
  • Time for change
« Reply #6 on: April 15, 2009, 02:46:47 PM »
Nice website, but I don't see specs anywhere there.  The early Honda shop manuals listed horsepower on the specs page.  Except for the 2 extra cylinders, there was little difference between the F model and the twins.  I believe there was only 1 MPH difference in top speed between the F and K.  And 36 sounds right.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline RRRToolSolutions
  • I love old Japanese bikes!
« Reply #7 on: April 15, 2009, 07:20:12 PM »
Jeff, it went like this -
CB/CL 350 Twins - 36 horses at some rpm I can't remember - I thought it was 9,000
CB350 Four - 34 horsepower at 9,000
R5/350 Yamaha piston port - 36 horsepower at 7,500
RD350 Yamaha reed motor (1973 and up) - 39 horsepower
A7 Kawasaki street twin- 42 horsepower
A7SS Kawasaki high pipe - 40.5 horsepower
GT380 Suzuki triple - 34 horsepower
305 Yamaha YM1 twin - 29.5 horsepower
305 Honda Superhawk twin/twin carbs- 30 horsepower
I can't remember the rest, but the Honda actually did quite well in all of my riding. A friend had the 1972 R5C Yamaha and the Honda was no match for it on the short end, but Yamaha gave up at 85, the CB350 G would slowly take me to 95. The GT380 was no match for the Honda in any contest. I own an Avenger today and will tell you that the Yamaha and Honda are no match - They say the little S2 triple Kawasaki 350 is faster than the A7. This little A7 will wheelie in the first 2 gears with ease. It just has the ugliest engine ever put on a bike, Whare are those carburetors now?
Regards,
Gordon
« Last Edit: April 15, 2009, 07:23:13 PM by Ilbikes »
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
Offline crazypj
  • I'm brill, me
« Reply #8 on: April 15, 2009, 11:11:11 PM »
In reality (and after dyno'ing) CB350 twins make about 27~28bhp AT REAR WHEEL.
 High compression pistons, 32mm carbs and half decent exhaust push it up to 34 bhp at wheel
 I don't care what the 'claimed output' is, that's what they do.
 350/4 makes less than 350 twin, is heavier and handles worse.........but, it has more potential with more cylinders spinning at higher rpm
PJ
Offline lordmoonpie
    • Moonpie
« Reply #9 on: April 16, 2009, 05:29:13 AM »
Holy cow !!!!
[/quote]
Oh you know me - throw everything away inside and start again :-)
It's worth pointing out that some guys in classic racing here are now getting over 50bhp on the dyno - verified proper rwhp!
My engine was fitted with:
CR gearbox
lightened balanced crank
self generating ignition
lightened Ti sump baffle plate
lightened clutch basket
lightened primary drive
lightened arrow conrods
HRC spec omega pistons
slipper camchain tensioner with flat plate race camchain
lightened rocker arms
megacycle race cam with slotted cam sprocket
ported, gas flowed head with lightened stainless valves, Ti springs caps and followers
DLC coated wrist pins
oh and a bunch of other stuff I can't remember ;D
It would rev cleanly to 13K and 13.5k at a push if you wanted to risk it. Some of the top guys go even further and take a stock engine and recut the exhaust ports 5mm down to get better gas flow etc plus use pressurised airboxes at the carb end. They're fantastic things to play with!
1994 Ducati 888 SP5
Offline Tom in Newcastle......Ontario
  • Newcastle Ontario
« Reply #10 on: April 16, 2009, 05:43:16 AM »
Are there any sites/forums similar to SOHC for the twins more specifically  74 360KO ......
yeah I knowthere's nothing like this site...
1978 cb 550k......stock,my first re-build
Loud pipes suck.......
If you buy something.........pay for it !
If you sell something .......ship it !
If you say you are going to do something......do it !
If you have a question about something......ask it !
When the seller answers ........let him know whether you still want it or not !
If you receive something .....let the seller know you got it !
If you get something and are happy/un happy with it .....let the giver/seller know !
If you have any kind of issue,shipping/receiving/quality/price/shipping charges etc !
Communicate
Offline lordmoonpie
    • Moonpie
« Reply #11 on: April 16, 2009, 12:23:46 PM »
You mean like this one? Talk to Bill he's Da Man!
http://hondatwins.com/forum/index.php
1994 Ducati 888 SP5
  • Newcastle Ontario
« Reply #12 on: April 16, 2009, 01:15:49 PM »
Wellllllllllll that was easy,I had done a Google search but maybe I used the wrong words.....Thank you Lord....
Communicate
