Author Topic: Proper Application of Di-Electric Grease?  (Read 1166 times)
Offline DrMark
« on: October 24, 2005, 09:01:06 AM »
Hi Gang....Now I'm ready to install the upgrades on my 1978 CB550. A friend helped with the Dynatek ignition. I purchased a CB900 set of coils on EBAY for $15. Had them checked...it was found to have a bad cable on #2. Purchased new cables and caps. I also purchased Di-Electric Grease. What is proper way of using the Di-Electric Grease? Inside the caps and connections? Or just around the connections? Packageing does not give clear instructions? Says it helps keep corrosion and water out of system. Thats why I'm asking if it goes inside or outside or both? Thanks, DrMark
1978 CB550K
1983 CB650SC Nighthawk
Offline mrblasty
  • Expertly
Re: Proper Application of Di-Electric Grease?
« Reply #1 on: October 24, 2005, 09:15:14 AM »
I always dab a bit onto whatever end is more open and then snap the connection together, as an example on light bulbs I coat the bayonet then stuff it in the socket.
I farted and made my son cry.
1973 Honda CB 750
1975 GL 1000
Offline dusterdude
« Reply #2 on: October 24, 2005, 09:17:29 AM »
mark,personally i would put it on both "sides" of the connection
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
« Reply #3 on: October 24, 2005, 09:18:55 AM »
Put some inside the spark plug cap too.
Offline DrMark
« Reply #4 on: October 24, 2005, 03:08:56 PM »
Thanks for the fast responses. I glad for the expertise on this site. Just wish the package was better marked with instructions.
1978 CB550K
« Reply #5 on: October 24, 2005, 05:13:22 PM »
There are no instructions! ;D
