Author Topic: ups battery question  (Read 2002 times)
Offline parm
« on: April 12, 2009, 05:43:02 PM »
has anybody used a ups battery in a place of mc battery. its a bit smaller, i need to be able to hide the battery under the seat, thats the only reason im searching for something smaller. the terminals seem pretty dinky.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=350185821708&category=48479&_trksid=p3907.m263&_trkparms=algo%3DSIC%26its%3DI%252BC%26itu%3DUA%252BIA%252BUCI%26otn%3D14%26po%3DLVI%26ps%3D54
« Last Edit: April 12, 2009, 07:09:22 PM by parm »
Offline cafebob
Re: ups battery question
« Reply #1 on: April 12, 2009, 06:22:50 PM »
I have used large ones as car batteries in the past.  If I remember right it could crank over the motor on a RX7 forever before it died.
CB
Offline 750goes
  • it will live
« Reply #2 on: April 13, 2009, 01:07:50 AM »
Depending on the brand of the battery - they are sometimes not strong enough to supply the cca (cold cranking amps) required for starting a motorbike. Certainly the larger AH rated batteries will work, but it seems you are after something that you can mount in any direction.... if it's a ups it may not be up to your task... look at the battery specs closely.
To get away from the lousy little connectors on these batteries - solder/heatshrink some decent cable on them and on the cable ends put your normal nut/bolt connection - with appropriate spark protection (larger heatshrink)..
Offline silver fox
« Reply #3 on: April 13, 2009, 04:56:27 AM »
Please let me know how you get on, as i am also in the market for a decent smaller battery to fit under my seat.
Kind Regards
SF
