Author Topic: cb200t carbs  (Read 1330 times)
Offline nealcuda1
  • 1975 cb200t, 1973 cb350f, 1980xj650, 1981xj550
cb200t carbs
« on: April 13, 2009, 06:34:20 AM »
How do you sync these carbs? I have the gauges but can't get them even.
Re: cb200t carbs
« Reply #1 on: April 13, 2009, 07:12:54 AM »
Take off he carb to filter rubbers and hold throttle wide open and set both slides so the bottom of slide is level at top of intake using the cable adjusters, then wind out both tickover adjusters and hold the throttle so bike is ticking over and wind in each screw individualy until it just picks up on that slide and back a tad(official Honda increment!)
Offline nealcuda1
Re: cb200t carbs
« Reply #2 on: April 13, 2009, 07:50:50 AM »
Thanks, I will try that tonight.
Re: cb200t carbs
« Reply #3 on: April 14, 2009, 11:30:05 PM »
Did it work?
Offline nealcuda1
Re: cb200t carbs
« Reply #4 on: April 16, 2009, 05:11:29 AM »
Yes that worked great. The left carb was adjusted to open a lot more than the right. Thanks for the help.
Re: cb200t carbs
« Reply #5 on: April 16, 2009, 07:03:41 AM »
No problem, just wanted to make sure I had remembered it correctly as its been a very long time since i did one of those
