Author Topic: HELP! How do I lock the primary shaft to remove the bolt? pic inc  (Read 1330 times)
Jheart
This sounds ridiculous, but for the life of me I can't figure out how to remove the 12mm bolt from the end of the secondary shaft, to pull out the primary. How did you keep it from spinning? As in how do you keep tension on the bolt so you can take it off?
I kow this is 101 stuff but it's killing me. I have a second 350F engine I'm working on, so I've been using that. Anyone feel like schooling me on this?
Here's a picture of the bolt I'm talking about
Offline tlbranth
Re: HELP! How do I lock the primary shaft to remove the bolt? pic inc
« Reply #1 on: April 13, 2009, 09:25:19 AM »
Well I haven't done this particular operation but from the picture it looks like a long pry-bar in between 2 teeth and levered against the shaft below (with appropriate padding) ought to hold it. I'd have someone do that for you and, using a box wrench on the bolt, give the wrench a sharp rap with a hammer.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
« Reply #2 on: April 13, 2009, 10:04:01 AM »
Put the clutch basket back on and jam a copper coin in the teeth
Jheart
« Reply #3 on: April 13, 2009, 10:23:57 AM »
So I'm not missing some clearly defined tool or step here right? It's okay to use a litte jimmy rigging on this one?  ;)
Offline r6100mph
« Reply #4 on: April 13, 2009, 10:33:04 AM »
put a leather glove on and grab hold of the shaft, take your air impact wrench (hopefully you have one) and it should come right off.
Took my cases apart last week, and there wasn't much torque needed for the bolt.
if you don't have an air impact I would maybe try to jam the leather glove in the gears, but would never stick anything metal into the gears or the clutch, just my 2 cents
« Last Edit: April 13, 2009, 10:35:35 AM by r6100mph »
Offline schneider419
« Reply #5 on: April 14, 2009, 01:50:29 PM »
with the clutch basket back on , a piece of alum. or copper will work fine.
        mike
Offline chrislib
« Reply #6 on: April 14, 2009, 03:34:45 PM »
stick a shop rag into the works/gears, a no mar solution.
Chris...closet Idlefiddler
#1975
1973 CB750K...CANDY BACCHUS OLIVE
Offline lordmoonpie
    • Moonpie
« Reply #7 on: April 15, 2009, 04:50:47 AM »
+1 to that - I actually just use a rag. Put the clutch basket on and feed in the rag until it grips, then just tweak off that bolt with a normal breaker bar. There's so little clearance between the teeth that a chunk of rag will do the same trick. I know copper is soft and won't damage the teeth but old pants are softer  ;D
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
« Reply #8 on: April 15, 2009, 08:09:43 AM »
True but i wear the old pants and the pocket always has a penny in it!!!
