Author Topic: *POP* from the carbs on acceleration  (Read 1340 times)
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« on: April 15, 2009, 11:23:36 AM »
every once in a while. I get a little POP from the carbs when I start off from the light.
I assume it's ignition timing, but I want some opinions.
    It's a cb750K8, I have dyna ignition and the plate is turned all the way clockwise. I'm unsure if thats advanced or retarded. there's no markings to tell me.
Offline torrinh
  • If you don't ride in the rain, you don't ride.
Re: *POP* from the carbs on acceleration
« Reply #1 on: April 15, 2009, 11:27:44 AM »
Why don't you just get a timing light and get it tuned? All the way clockwise is probably not correct. I have a dyna-s with plenty of room to adjust either way.
1983 Kawasaki GPZ 750
1978 Honda CB750K w/ 1976 CB750F1 motor
1979 Suzuki GS550L
  • Like a well oiled
    • Undead Asphalt
« Reply #2 on: April 15, 2009, 11:53:54 AM »
my timing light is broken, I'll have to borrow one. still i need to know which way is advance.
« Reply #3 on: April 15, 2009, 12:13:49 PM »
Popping in the intake is either advanced ignition timing, lean mixture, or leaking intake valves.  Which would you prefer to investigate first?
  • Like a well oiled
    • Undead Asphalt
« Reply #4 on: April 15, 2009, 12:16:20 PM »
I'll take ign. timing, then mixture, then the intake valve.
Offline Frankenkit
  • Industrial Strength
« Reply #5 on: April 15, 2009, 12:17:59 PM »
dunno about your carbs but on mine (the PD 50s) the air cutoff valve was used to reduce/eliminate lean popping on deceleration... dunno if it'd be the same issue.
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
« Reply #6 on: April 15, 2009, 12:23:38 PM »
No, the air cutoff circuit is to prevent the >exhaust< lean popping on deceleration.  It cuts off the oxygen needed to sustain fuel burn in the exhaust.
Offline timdhawk
  • 1978 CB750K
« Reply #7 on: April 15, 2009, 03:35:56 PM »
IC, do you not have the instructions for the Dyna? On mine you use a electronics tester light, not a designated timing light...and mine is also not all the way forward, FWIW.
In deeper than I should be...
  • Like a well oiled
    • Undead Asphalt
« Reply #8 on: April 15, 2009, 04:09:09 PM »
I do not have the instructions. it was on the bike when i got it.
Offline eurban
« Reply #9 on: April 15, 2009, 04:45:20 PM »
Dyna recommends setting the timing at full advance and using the advance timing marks.  Do it correctly; get a timing light.  Probably not wise to ride much until you do.
  • Like a well oiled
    • Undead Asphalt
« Reply #10 on: April 15, 2009, 05:07:37 PM »
AH-HAAA! fixed it! there was a tight intake valve on cylinder 2!
thanks for all the help.
thanks TwoTired!
