Author Topic: CB550 Clutch springs  (Read 1572 times)
Offline Bodain
  • I love the smell of fresh asphalt in the morning!
« on: October 25, 2005, 07:08:32 AM »
I very quickly find that you just never know what a previous owners did on one of these older bikes.
Case in point.........  I picked up a set of new clutch plates for the 75 CB 550 for $5.00 off of E-bay.
I didn't really feel like I needed them because the clutch was working fine. Still for $5.00 I decided
to replace with new ones.
With the clutch disassembled I went to measure the clutch springs. Manual states 30.5 mm in uncompressed
state. These four springs were 35 mm..... Hmmmm
The clutch prior to disassembly works fine. What is the impact of longer springs? I assume this would just
make clutch movement a bit stiffer.
2009 Suzuki TU250
2014 Honda Grom
1984 Kawasaki GPZ 750
2005 Yamaha Zuma 50
1974 Honda CB 750
1979 Kawasaki Z750 Twin
Offline dusterdude
Re: CB550 Clutch springs
« Reply #1 on: October 25, 2005, 08:58:08 AM »
i would think a bit stiffer too
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Dennis
« Reply #2 on: October 25, 2005, 09:14:21 AM »
..... I went to measure the clutch springs. Manual states 30.5 mm in uncompressed
The manual normally states minimum acceptable length. You didn't tell us what the specified length is.
It is certainly possible that these are some type of aftermarket spring also. Aftermarket springs are typically a little stiffer.
Finally if it ain't broke ...... (and since you already have it apart- if all the parts look OK) don't f..k with it!!
