Author Topic: Greetings from Portland, Michigan! ('75 550F)  (Read 450 times)
Offline d_soles
  • My two girls...
« on: April 17, 2009, 09:44:24 AM »
I have recently acquired a field-find, a 1975 Honda CB550F.  Suprisingly, the engine actually turned over.....but, the carbs are seized, as are most of the switches and the rear-wheel.  Yay. Anyway, my name is Doug, and I'll be here.
'75 CB550F - Field Beater at it's best....
Offline Bob Wessner
  • "Carbs Suck!"
Re: Greetings from Portland, Michigan! ('75 550F)
« Reply #1 on: April 17, 2009, 10:02:44 AM »
Welcome. Sounds like you have your work cut out for you.
jeremy112
« Reply #2 on: April 19, 2009, 10:39:01 AM »
Welcome aboard!  I am over in the SE section of the state :)
« Reply #3 on: April 19, 2009, 11:02:39 AM »
Use a heat gun to free the carb slides.
Offline burmashave
  • Forum Immoderator
    • burmashave.net
« Reply #4 on: April 20, 2009, 07:49:01 AM »
Welcome, Doug. You do have just a bit of work ahead. Good luck.
Yay, back at you. ;-)
Quote from: SOHC Digger, RIP
'77 CB750k
