Author Topic: gas in carb  (Read 1126 times)
shovelhead63
gas in carb
« on: April 21, 2009, 01:02:39 PM »
Ive got a 71cl450 it has double over head cam.Am i in the right place.I took the carbs off to clean them up,when i put them back on,no gas will shoot up in the cylinder.Whats the trick to that?It has gas in the bowl.Thanks
Offline myhondas
  • Not really such a
Re: gas in carb
« Reply #1 on: April 21, 2009, 01:08:47 PM »
probably should repost this under "other bikes" since it is a DOHC and not a SOHC
1974 CB 750 K4 SHOWROOM
1965 C100 CUB 50 (PIT BIKE)
1996 VF 750 CD daily rider
SOHC# 5105 11228
Offline heffay
Re: gas in carb
« Reply #2 on: April 21, 2009, 01:38:21 PM »
do you mean the cylinder of the carb?  which you might be able to peer into to see.
or do you mean the actual cylinder?  which you should not be able to see gas "shooting" up into.
your engine needs to make vacuum pressure in order to pull gas/air out of the carbs... is it running when you check?
basically... i think we need some more info.
unless someone else knows exactly what he's trying to say.
Offline my78k
Re: gas in carb
« Reply #3 on: April 21, 2009, 02:47:13 PM »
Unless there is supposed to be an acccelerator pump I don't quite follow either...
Dennis
Offline mark
Re: gas in carb
« Reply #4 on: April 21, 2009, 11:08:02 PM »
CL450 carbs don't have accelerator pumps. If there's gas in the bowls, flip the choke on and it should fire....
if all else is well.
Happy trails.
F you mark...... F you.
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
Re: gas in carb
« Reply #5 on: April 23, 2009, 10:49:56 AM »
Unless of course your jets are completely clogged?
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
Offline heffay
Re: gas in carb
« Reply #6 on: April 23, 2009, 11:43:33 AM »
harley guy musta gotten it started.   ;D
