Author Topic: chain differences  (Read 929 times)
Offline mrblasty
  • Expertly
chain differences
« on: October 26, 2005, 04:25:59 PM »
I see You guys talking about o-ring and non-o-ring chains, what's the difference and what kind will I need for my '73 cb750?
Thanks in advance.
I farted and made my son cry.
1973 Honda CB 750
1975 GL 1000
Offline Bob Wessner
  • "Carbs Suck!"
Re: chain differences
« Reply #1 on: October 26, 2005, 05:11:46 PM »
The "O" ring chains actually have a rubber "O" ring surrounding the pin in between the side plates. I keeps the lube in the rollers so relubing is not necessary as frequently, but makes the overall chain width greater. Depending upon the chain you select (if you go the o-ring route) check to make sure you have enough clearance between the front sprocket and the engine case. Do a search here on it, you will find several threads on this topic.
Offline mrblasty
  • Expertly
« Reply #2 on: October 26, 2005, 06:39:58 PM »
Thanks for the tip.
1973 Honda CB 750
1975 GL 1000
