Author Topic: Stop Light Switch - Front Brake - 750K4  (Read 2240 times)
Offline Jiminy Indy
« on: April 23, 2009, 01:03:51 PM »
Honda p/n 35350-300-016 is dicontinued. I checked the continuity and, yes the switch is bad. Any suggestions as to an alternative? Thanks,
Of all the things I've lost, I miss my mind the most.
"Shot up the alley and then cut across the street" - now that's some violence you can appreciate!
Offline mystic_1
  • 1970 CB750K
Re: Stop Light Switch - Front Brake - 750K4
« Reply #1 on: April 23, 2009, 01:06:32 PM »
I'd think that any front brake switch with the right threads would be suitable, which would include all CB's at least through to the DOHC models I think.
There's always eBay, DSS, Yamiya, et al.
mystic_1
- John Augustus Shedd
Offline myhondas
  • Not really such a
1974 CB 750 K4 SHOWROOM
1965 C100 CUB 50 (PIT BIKE)
1996 VF 750 CD daily rider
SOHC# 5105 11228
Offline mikeb4
  • Building and riding and building ....
    • Mikeb4's website
« Reply #3 on: April 23, 2009, 07:05:09 PM »
I have had great luck with Goodridge Single Bleed BL Banjo Bolts ....
http://www.denniskirk.com/jsp/product_catalog/Product.jsp?skuId=193936&store=&catId=&productId=p193936&leafCatId=&mmyId=
I use the double bolts when using dual stainless braided lines.  The brake pressure triggers the light ... work great and clean install.
1978 CB750K CR750 Replica
1995 CB1000F
1994 Sportster Bobber
1977 CB750SS Cafe'
1999 ZRX
Offline Jiminy Indy
« Reply #4 on: April 24, 2009, 07:56:50 AM »
Hi Mike - thanks fopr the information. I assume that you re-plumbed the whole front brake line and ran a single line from the master cylinder to the caliper putting the sensor on the handlebar? Wonder what the thread size is on the OEM banjo bolts (before I pull them off) to see if there's a sensor banjo bolt that would fit in the existing splitter?
Offline friedfish80
« Reply #5 on: April 24, 2009, 08:03:58 AM »
I'm in the same boat as you are. I aquired a MC off a 77,78 cb750. The stop light switch Is a pin switch on the lever itself. I just now need to rebuild it before it goes on the bike
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #6 on: April 24, 2009, 08:22:32 AM »
Z1 sells one that goes straight into the brake lever banjo bolt.
Offline Jiminy Indy
« Reply #7 on: April 24, 2009, 08:41:42 AM »
Both Dennis Kirk & Z1 sell the Goodridge banjo bolt with the sensor. Z1 is cheaper (p/n FS12-010). The 3 OEM banjo bolts (p/n 90145-300-010) are all the same so the new sensor banjo bolt should fit the splitter located behind the headlight as well as the handle bar master cyclinder.
Offline mikeb4
    • Mikeb4's website
« Reply #8 on: April 24, 2009, 09:05:55 AM »
Actually on all of my bikes I have either put a GL1000 front end on the K's or had Super Sports so I always run a double banjo bolt brake light switch from the master cylinder with two braided lines, one directly to each caliper.  However, with a single to a splitter the single Banjo would work great at the Master Cylinder in the same manner, then just run the switch wires into the headlight bucket to connect to the harness.  Best of luck!
1995 CB1000F
1977 CB750SS Cafe'
1999 ZRX
« Reply #9 on: April 24, 2009, 10:04:16 AM »
