Author Topic: project fuzzycycle............i hate motorcycles!....video added  (Read 5089 times)
Offline 1080
Re: project fuzzycycle............i hate motorcycles!....video added
« Reply #25 on: April 30, 2009, 09:49:06 PM »
Take each tappet cover off and look for oil. If you see very little oil. Squirt oil in each tappet cover try to shoot over the cam towers. You may have one last time before you do damage to cam and tower bearings. If it is smoother stop and disassemble and look for blockage.
« Last Edit: April 30, 2009, 10:26:30 PM by 1080 »
fuzzybutt
« Reply #26 on: April 30, 2009, 10:04:19 PM »
very little? try next to none in the 3 i've pulled. well i guess it comes back apart this weekend maybe. too disgusted with it right now.
« Reply #27 on: April 30, 2009, 10:12:28 PM »
Gordon's frame kit looks better all the time! You said you fudged the valve lash settings. Explain. Thats probably not the problem since it ran fine last time but.....
What sealer did you use and where did you use it?
Offline 1080
« Reply #28 on: April 30, 2009, 10:21:09 PM »
 I think you may have block the main oil passages. The oil goes up the center cylinder studs. There is couple of  o-rings. Look at those. Start by re moving the cam and inspect the tower bearings/ cam surface. They can take alot before they seize up as long as you pre-lubed before assembling.
Sometimes it is a learning curve.
Take photos.
Offline Hush
« Reply #29 on: May 01, 2009, 12:37:31 AM »
Damn and it was starting to look so good too. :(
ev0lution7
« Reply #30 on: May 01, 2009, 07:32:21 AM »
dont worry it will be all OK!
just take your time and dont rush and keep your mind focused! ;D there have been many times i thought i F'd p my motor and it turned out it was ok.... just take your time!
heck its only may 1st you have got ALL summer long to ride!
fuzzybutt
« Reply #31 on: May 01, 2009, 08:17:34 AM »
sealers arent allowed in my shop, not since i worked on a bmw inline 4 that had a little chunk of sealant come lose and sieze a cam, snapping the cam in 2 because of a blocked passage. tonight, once it cools down i guess it gets torn back down.
Offline UnCrash
  • Pass
    • My Blog
« Reply #32 on: May 01, 2009, 09:11:27 AM »
Keep at it Fuz!
I'm glad the cylinder jugs were quality.  You'll be riding your new steed soon!
ev0lution7
« Reply #33 on: May 01, 2009, 11:31:48 AM »
maybe a dog pee'd on your bike or in you valve cover...
AND thats the strange noise?
fuzzybutt
« Reply #34 on: May 01, 2009, 02:20:17 PM »
i sold the damn thing this afternoon, guy is supposed to be here tomorrow with the cash and a trailer.
Offline kghost
« Reply #35 on: May 01, 2009, 02:22:09 PM »
Can I have my badges back?  :D
Stranger in a strange land
fuzzybutt
« Reply #36 on: May 01, 2009, 02:29:26 PM »
yes
fuzzybutt
« Reply #37 on: May 01, 2009, 02:33:35 PM »
i almost wheeled it outside today and burned it. lack of oil to the top end, cam and holders trashed, aluminum shavings in the pan.
Offline kghost
« Reply #38 on: May 01, 2009, 02:36:08 PM »
Well...........If you didn't sell it....I'll send ya a cam and Towers.....
Have one somewhere already out.....
PM'd ya a phone number....give me a call if your up to it.
« Reply #39 on: May 01, 2009, 02:43:43 PM »
Fuzzy,
It's time for a change of heart brother. Take KG up on the offer. Really, the majority work on them more than we ride them. You've done too much at this point to cash it in. Hang in.
Offline kghost
« Reply #40 on: May 01, 2009, 03:32:57 PM »
Found.
Hang in there Fuzzy....unless your out loading the bike in someone elses truck  :-[
fuzzybutt
« Reply #41 on: May 01, 2009, 04:09:49 PM »
appreciate it Tim, please send ahead. i just get frustrated some days. weaning myself off the pain meds makes me cranky  ;D
Offline heffay
« Reply #42 on: May 01, 2009, 04:22:11 PM »
drama queen and/or cranky... yes.   :P
dude, don't do that to us... we are just as susceptible as you are!
i'm of the firm belief that something is loose and can be adjusted.  look around, see what you come up with.
Offline Burke
« Reply #43 on: May 01, 2009, 05:17:38 PM »
Ummm....that doesn't sound too good....
Can you see oil in the valve cover?
Seriously sounds like a couple valves are too loose.....least that was my impression from the video sound.
For educational purposes, what was the noise that gave it away?
Offline 1080
« Reply #44 on: May 01, 2009, 05:21:07 PM »
Did you find what caused the blockage?
Hey I've been there.  Mine was a $900 mistake.
O-ring's right diameter but wrong thickness. Blocked the oil from getting up to the top end after the head was torqued down.
Taking it apart & fixing the problem, then reassembling gives you more understanding how they work. Don't give up.  YOU CAN DO IT.
Offline RRRToolSolutions
  • I love old Japanese bikes!
« Reply #45 on: May 01, 2009, 05:59:16 PM »
Jeff, the oil pressure is all wrong too. Mine is 60 pounds + when cold and never below 45 hot. You know I can help.
Hey, I'm going to be in Columbia tomorrow. I'm picking up a 2009 ST1300 ABS. Want to grab some lunch?
Gordon
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
fuzzybutt
« Reply #46 on: May 01, 2009, 06:06:55 PM »
i havent gotten back into it, i'll head out to the garage around 10 or so when it's cooler out there.
fuzzybutt
« Reply #47 on: May 01, 2009, 07:50:11 PM »
Gordon
doing the zoo tomorrow with our grandbaby gordon but thanks for the offer!
Offline kghost
« Reply #48 on: May 02, 2009, 08:26:34 AM »
Fuzzy...I'll get it shipped out to you monday. Rode the 400 to the shop today.
Could you give us the whole history of the Engine?
You'll have some disassembly, cleaning, and reassembly to do before the parts get there....you need to get the metal bits out and check the bearings.....
fuzzybutt
« Reply #49 on: May 02, 2009, 09:34:56 AM »
it's the bottom end of a k5 motor, with an f0 head and cam. i got the top end off last night and pulled the oil pan and cleaned it and the oil filter out. bearings looked ok.
