Author Topic: need info on smoking engine  (Read 861 times)
Offline jamesb
« on: April 24, 2009, 05:06:30 AM »
my 74 cb550 is starting to smoke after riding for about half of hour sometimes it does it and sometimes not has anyone used anything in their oil to help stop this if they had the same problem it get's quite embarassing sometimes thanks in advance for any info
jimmy
Offline Bodi
Re: need info on smoking engine
« Reply #1 on: April 24, 2009, 05:59:22 AM »
Get it an ashtray?
Offline OakBehringer
« Reply #2 on: April 24, 2009, 11:09:52 AM »
Blue smoke? You're burning oil. "How is the oil getting into my cylinders?" you should be asking yourself. The two most common answers to that question are "past the rings" and "down the valve stems". If you have bad valve stem seals you would typically see oil smoke on a cold start as the oil would be dripping past the seal, into the cylinder, while sitting. I'm going to go with rings. They're around your pistons, and they're not sealing with the cylinder wall. Oil is getting past them. Either way, you're looking at a top-end rebuild.
1974 350 Four - SOLD
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
