Author Topic: Thumper Tech  (Read 2470 times)
Offline gerhed
Thumper Tech
« on: April 24, 2009, 07:38:31 AM »
Due to the fact that the engine is not in the
original frame, the kickstart conflicts
with the footpeg position.
Bracketry has been designed to allow the footpeg
to be pivoted out of the way for starting.(BTW--it refuses to start)
Top pic shows starting position.
Bottom pic shows footpeg in proper position.
          83 XL600R in CB360 Frame
Offline Ecosse
  • Member #4139
    • My 550 walk around video
Re: Thumper Tech
« Reply #1 on: April 25, 2009, 06:20:14 PM »
hope you don't mind but one day i'd like to try this swap! brilliant.
btw: i'm relieved honda had the foresight to label the kickstart arm. otherwise i'd likely spend all day pumping that thing looking for the well water! thanks honda.
1974 CB550K
                                  Your 1%er name
Offline gerhed
Re: Thumper Tech
« Reply #2 on: April 26, 2009, 04:49:45 AM »
Due to starting problems, the thumper has been temporarily relegated to static kinetic art status.
--But I am still working on a starting roller mechanism for the thumper.
Current plans call for the roller to be driven by a power take off on the electric three wheeler.
Anytime I can use another turnbuckel, I do !
« Last Edit: April 26, 2009, 04:55:05 AM by gerhed »
Offline Ecosse
  • Member #4139
Re: Thumper Tech
« Reply #3 on: April 26, 2009, 09:40:57 AM »
the imagery of you muscling these skateboards away from some slack jawed, inexplicably cynical, teenager in desperate need of a haircut makes me smile.  ;D
the folks at the hardware store must rejoice when they see you walk in.    :D
1974 CB550K
                                  Your 1%er name
Offline gerhed
Re: Thumper Tech
« Reply #4 on: April 26, 2009, 10:37:15 AM »
Nine scateboards into the project, so far.
When used to cradle a PVC tube, the scateboard wheels are self-aligning.
« Last Edit: April 26, 2009, 10:39:54 AM by gerhed »
Offline Ecosse
  • Member #4139
Re: Thumper Tech
« Reply #5 on: April 26, 2009, 11:06:49 AM »
have you posted already the self starter in action?
how did you address properly aligning the moto mill in the cb frame? fitting challenges?
1974 CB550K
                                  Your 1%er name
Offline gerhed
Re: Thumper Tech
« Reply #6 on: April 26, 2009, 02:21:19 PM »
The self starter has yet to see action.
Alignment of the thumper engine was done
by resting the engine in the frame,
putting the chain on and eyeballing.
Due to the design of the main engine shaft (splines)
you have about 3/4 inch to play with.
