Author Topic: CB550 luggage rack mounting points?  (Read 2770 times)
Crippler
« on: April 24, 2009, 02:58:39 PM »
Those of you with luggage racks, where do they mount up to? i know it depends on the model and year for each rack, but i cant seem to figure out if i can use one... you see, i dont have a rear fender or grab rail, and i'm wondering if that will nix the possibility of a rack....
Re: CB550 luggage rack mounting points?
« Reply #1 on: April 24, 2009, 03:04:46 PM »
Luggage racks that I have, connect at the rear shock mount, the fender bolt, and either the grab bar, or the rear tail light.  The grab bar is much preferred over the rear lamp mount, as the lamp mount transfers rack loads to the fender, which causes the fender to flex, and eventually bend then crack.
At least, that's been my experience with the Cb550s.
Crippler
« Reply #2 on: April 24, 2009, 08:50:21 PM »
hmmm
http://cgi.ebay.com/ebaymotors/1976-honda-cb-550-cb550-luggage-rack_W0QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247QQcategoryZ35581QQihZ016QQitemZ260370930790QQrdZ1QQsspagenameZWD1V#ht_630wt_1055
that looks like just four mounting points...the top shock bolt... and dont know exactly to what else (i'm picking up the CB from my brother in two weeks)
you can see that the fender and grab rail were removed from my future bike, turn signals are bolted in place of the grab rail
 (the sidemounted license plate is gone now, so it shouldnt interfere...)
suppose i could just wait til i get the bike... but i'm anxious. lol
« Last Edit: April 24, 2009, 08:54:33 PM by Crippler »
Offline chippyfive50
  • NO PEE ON TEPEE
    • thesweetimpala
« Reply #3 on: April 25, 2009, 05:06:03 AM »
You can just use the shock mounts and the holes where you have your signals. I made some standoffs(painted black) from a piece of hollow steel stock so the mount would fit properly. I have LOADED it down when I go on camping trips, no problem.
You may notice, I have no turn signals, so that made it a bit more simple.
« Last Edit: April 25, 2009, 05:08:48 AM by chippyfive50 »
SOHC Member#4000
71' 500K0 #1021237--E1108327
78' 550
72' 750K2(sold to "Craig")
74' 750K4 #2306334--E2303422
73' CL175
http://gallery.sohc4.net/main.php?g2_itemId=14013
Crippler
« Reply #4 on: April 25, 2009, 02:37:02 PM »
ok ok. thats exactly what i wanted to see. i can make something work. thanks!
