Author Topic: cm250c (rebel) with a stripped spark plug hole...  (Read 2349 times)
Offline cbr-eric
« on: April 27, 2009, 01:43:15 PM »
I have the spark plug hole and it is now mostly smooth... now it has tiny plugs in it now, wondering what anyone would do in this situation... It is actually too small a plug to get a heli-coil, already tried that route.  so I am now thinking that maybe I can get a plug with the same depth and heat range and maybe just a physically bigger plug, then drill and tap for the increased size?  anyone have any better ideas, or maybe you have tried the same thing with sucess?? any help or ideas would be great, thanks guys!  Eric
k8 project, a long way from done.....
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
Re: cm250c (rebel) with a stripped spark plug hole...
« Reply #1 on: April 27, 2009, 03:02:32 PM »
Have you done a valve job recently?  Might be the time to find a donor head and freshen up the valves while you're at it :)
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
Offline cbr-eric
« Reply #2 on: April 27, 2009, 04:02:04 PM »
it has like 9k miles on it and runs great, or it did...
fuzzybutt
« Reply #3 on: April 27, 2009, 06:54:29 PM »
heli-coil, i did one on a friends escort when the plug hole stripped years ago. it's still together.
Offline RRRToolSolutions
  • I love old Japanese bikes!
« Reply #4 on: April 27, 2009, 07:05:20 PM »
Jeff is 100% - have those threads replaced with a helicoil. You can do a google search and find video showing the process. They make kits just for the sparkplug threads.
Regards,
Gordon
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
fuzzybutt
« Reply #5 on: April 27, 2009, 08:36:34 PM »
very easy to do too, goop the drill and tap up real good with lots of grease to keep shavings out of the cylinder and you might not have to even pull the head. worked out ok for the job i did.
Offline cbr-eric
« Reply #6 on: April 28, 2009, 04:10:46 AM »
I know they work great, but they actually dont make a heli coil for the size and thread pitch of these plugs, went to fastenall and checked. the guy even called all his distributors. :( any other ideas?
Offline cbr-eric
« Reply #7 on: April 28, 2009, 04:17:07 AM »
here aer the specs on the plugs it has now..
http://sparkplugs.com/more_info.asp?otherMotiveID=225032&pid=3259
Offline cbr-eric
« Reply #8 on: April 28, 2009, 04:46:46 AM »
now I am thinking they were wrong...  anyone know if this kit would work?
http://www.tooldiscounter.com/ItemDisplay.cfm?lookup=HEL5523-10
is the plug I have a 10mmx1.0?  or is the only way to check to take it to my local hardware store and have them check it for me?  thanks guys, really want to get the wifes bike back on the road!
Offline cbr-eric
« Reply #9 on: April 29, 2009, 07:07:18 AM »
anyone? bueller?? :)
Offline Frankenkit
  • Industrial Strength
« Reply #10 on: April 29, 2009, 07:21:17 AM »
As long as the diameter and thread pitch are right, I don't see how it wouldn't work.
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline mark
« Reply #11 on: April 30, 2009, 09:34:39 AM »
Spark plug thread is 10X1.0mm
I would not recommend trying to tap the hole with the head on. All it takes is one little chip or nugget of carbon to really chew up a piston... and/or cylinder. There isn't much room in there.... having the piston down for tap clearance may open a valve..... tap may hit open valve and bend it. seen it happen.
best of luck.
F you mark...... F you.
Offline cbr-eric
« Reply #12 on: April 30, 2009, 12:10:33 PM »
thanks on both points!
Offline Frankenkit
« Reply #13 on: April 30, 2009, 01:48:54 PM »
Oh, and I agree 100% with Mark. Some people will tell you it can be done with enough grease. This is probably true, if you do it REALLY slowly and clean out EVERY little bit as you go, but then... you'll never really know if you got them all.
...and you'll keep thinking about it at 3am...
anyway, it's not worth the self-induced paranoia.
1973 CL350- Lola?
Stuff for sale
