Author Topic: Off the shelf Fuel Injection for our old bikes  (Read 26130 times)
Offline KB02
« on: April 28, 2009, 05:07:57 AM »
One of the recent threads by a very lucky member mentioned about a Hilborne Fuel injection system.  I did a little research out of couriosity and came up with these results (after a nice e-mail from the company):
Model    *75M4     Price    $1,375.00
*PG150C or *PG150D  Fuel Pump  $575.00 or $605.00
(4) Ram Tubes   $60.00 - $90.00 per set depending on the bore size of the injector
*F1200/149   Fuel Filter      $140.00
END521B-6   Shut odd Valve    $75.00
*END510C   Hi Speed Cut off Valve (alcohol only)   $55.00
They do mot make a pump drive for our Motorcycles but you can get one (at least for the 750) at:
Bailey Chassis Co
Hendersonville, Tn
Ph: 615-822-7041
www.baileychassis.com
Pricey set up, makes me wonder if it's worth it. (I'll be running carbs, thank you).
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline JLeather
Re: Off the shelf Fuel Injection for our old bikes
« Reply #1 on: April 28, 2009, 05:22:27 AM »
Yeah, but Hilborn setups look BAD A$$ man.
Offline KB02
« Reply #2 on: April 28, 2009, 02:47:23 PM »
Well, there is that...
Also saying, "Yeah, I converted it over to Fuel Injection..." siunds pretty good, too.   ;D ;)
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline Soos
« Reply #3 on: April 29, 2009, 07:41:12 AM »
A line I have YET to be able to say....
$$ is the only barrier so far.
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline Geeto67
  • A grumpy
« Reply #4 on: April 29, 2009, 08:46:17 AM »
Hilborns are a mechanical fuel injection setup - not what most people think when they hear FI. Good for mostly race setups, lousy as a street induction. You are probably no better off with this setup than you would be with a set of sandcast CR carbs with no idle circuits.
If someone were savy with the megasquirt controller and handy with a tig torch they could make up an FI system for the CB750 no problem costing about half of what a hilborn costs. The hardest part of FI is programming the computer and it is only difficult because it is labor intensive.
Although it is easy to pirate the throttle bodies off of newer sport bikes it is not necessary to have individual throttle bodies for each cylinder. A central throttle body (like one off an OBD I honda civic) and a common manifold with injectors at each intake inlet in the head will work just as well and be simpler to setup.
Putting real Electronic Fuel Injection on a cb750 has another problem however and that is that our alternators flat suck. They do not generate enough juice allow a continously running fuel pump, and fire injectors, run a computer, and all of the lights in normal street use. I can see for Drag racing or LSR racing where it could be a useful tool, but the first time you get caught in traffic the bike will run out of juice fast.  Solving this problem has been one of the reasons why I have not built the system I put together on paper out of junkyard parts. Basically I would need to figure out a way to adapt a charging system from a modern sportbike to the cb750 and I just don't have that time or energy.
On a side note I am trying to solve a similar problem on my cb450 LSR bike so I can run oil pumps for the turbo (the cb450 makes lousy oil pressure - about 15psi max). If I fgure it out I will be sure to let y'all know about it.
Maintenance Matters Most
« Reply #5 on: April 29, 2009, 09:04:38 AM »
I have seen a couple of Hilborn injected bikes on the street, twins..
As far as I know, they only have one choice of jetting, no triple (or more) adjustments like carbs.
geeto, you sould be able to run a beltdrive pump of the cam, or alt side or starter hole.. if you can find or build a pump. Should be doable, helped a guy build a drysump pump for a V8 once. Another buddy when he turbo'd his HD, built a small pump, either to oil the turbo, or evacuate the oil out of the camcover.
Offline Geeto67
  • A grumpy
« Reply #6 on: April 29, 2009, 09:34:34 AM »
I have seen lake injector setups on street bikes also, doesn't mean they run great in traffic or at part throttle applications.
With mech FI the way you meter fuel is through pressure regulators, airbleeds, and distrubition blocks. My father used to be a pro at setting up old corvette FI (we still own all the factory tools and gauges from the 1950s) and those have very little adjustment.
I have thought about a mechanical pump but really, I like the electric pump idea because if we blow the motor we can just plug a new cb450 motor into the frame and go right back to racing. One of the goals of this project was to do as little one off fab to the bike as possible so that we could get parts anywhere in the country. Even the electric pumps can be substitued for electric airplane fuel/oil pumps in a pinch (they have a much shorter life) and can be sourced from any decent FBO at a local airport.
Offline MJL
  • Don't listen to me, I'm no
« Reply #7 on: April 29, 2009, 09:56:34 AM »
Who was the feller here that did do a newer EFI setup?  Maybe we should drag that post up and see if he's had any street time with it.
« Reply #8 on: April 29, 2009, 10:09:41 AM »
its 750ss, I think.. from N'Awlins..
has an ongoing post on project bikes, as far as I know.
The earliest 4cyl bike FI , i recall was the Kawi LTD with the chrome covers, back in the 80s  or so. Just mentioning, in case it has simpler or easier to replace electronics than newer systems. Aslo I think the engine design is closer to ours than the newer stuff with FI
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
« Reply #9 on: April 29, 2009, 10:19:26 AM »
85 Kawasaki GPZ750 Turbo has FI.
A real archaic set up but it does the job. Might be able to adapt the 750 throttle bodies to our Honda spacing.
Then it's just a question of crank tirggers and powerage.
Come to think of it so does the same year range GPZ1100. And the spacing doesn't have to change to fint the Kawi 750.
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
Offline Geeto67
  • A grumpy
« Reply #10 on: April 29, 2009, 12:38:11 PM »
GPZ750 Turbo, cx500 turbo, and the XN85D turbo were all fuel injected. the Seca Turbo was not.
The Original Z1r-TC was originally planned to be FI  but in the end ran a modified (by ATP) carb/injector (kind of like a mechanical FI or a lake injector but really still a carb).
 the 1980 Kz1000G was the first commercially available japanese Fuel Injected motorcycle. the 1982 cx500 turbo was the second.
The kz1000G FI was horrible. The computers failed if you tried to start the bike with a flat battery (low voltage killed the unit quick) and they were the most common failing part. They cost $1500 to replace back in the day. The second most common failing parts were the fuel pump and the mass air flow sensor. So basically everything that made the FI on these bikes work was junk. Apparently low voltage was a common problem on these bikes because the load of running all this stuff was a drain on the old KZ1000 charging system. Low voltage is also what burned out the electrics so I guess Kawasaki didn't have the FI thing figured out with regards to old bikes either.
I didn't say it was impossible to build a cb750 with modern FI and the stock charging system. I lived in New Orleans for 5 years and I can tell you their worst parade traffic is still not as bad as New York City at 2 a.m. on a week night. As long as you had a really good battery and you were above break even charging for the majority of your ride I imagine you could probably live with a bike like that in New Orleans. However, I once ran down my stock cb750 K5's battery in midtown rush hour so an FI for commuting would be a no go without a beefier electrical system.
Offline Geeto67
  • A grumpy
« Reply #11 on: April 29, 2009, 12:47:45 PM »
one more thing - just cause it is old doesn't mean it will work with older bikes. In fact some of the newer stuff is probably better suited to retrofitting on the basis that electrical components have improved in the last 25 years. I betcha the fuel pump on a brand new ZX10 draws less amps than the one on a GPZ750 turbo and puts out more psi too.
But why bother with the weight of four throttle bodies when you can have one throttle body with TPS, 4 injectors, one fuel rail, one fuel pump, an O2 sensor, and your megasquirt computer to run your whole shebang. Get a set of Ken's dual carb manifolds (cyclexchange.net), build a plenum box, weld in injector bungs, slap on a single throttle body and start programming.
Then if you want to turbo the thing it is one pipe into the throttle body from the turbo and robert's your father's brother.
If you really wanted to get advanced get a knock sensor and a dyna2000 so that the 'squirt can retard the timing if the motor starts to detonate.
Offline HavocTurbo
  • Can you tell?
« Reply #12 on: April 29, 2009, 02:18:08 PM »
Don't get me wrong... I wasn't saying use older stuff. Just might be cheaper. That's all.
If I could, I would buy a whole zx-14 setup and go from there. Or go with the single TB and multi point injection idea, but I dont like to fab FI from scratch. I'm a chicken.
As far as using a turbo on the system....
Everything is dependent on compressor size and your desired HP gains. If you go too big the FI won't be able to deliver, and if you go too small, there's no point in spending all that money on a giant FI system.
In the end you are limited by electrical requirements. If there was a better replacement charging system for every bike out there, we could do things like run batteryless, and FI on everything.
Some things it seems.... are not meant for all this modern stuff no matter what people try.
Now for my 85 GPZ.... I think 250+ HP could be had with GPZ100 throttle bodies, a bigger turbo, bigger injectors, and a Power Commander.... and of course adding a few other parts.
Seeing as how it had FI from the factory, I have a starting point.
09 XL883L - No Name
Offline Joel
« Reply #13 on: April 29, 2009, 02:35:59 PM »
I like the mechanical fuel pump suggestion for street use.  Any suggestions on where the shaft power could be taken from on one of these SOHC 4 bikes?
Offline HavocTurbo
  • Can you tell?
« Reply #14 on: April 29, 2009, 02:42:03 PM »
One of two off hand.
Left side:
Run a two v-belt pulley for remote alternator and oil pump
Right side:
Get a smaller cog pulley and mount it as the retainer for the points advance mechanism.
Either way electrical would be LOTS easier with a pressure regulator.
09 XL883L - No Name
Offline MJL
« Reply #15 on: April 29, 2009, 03:17:39 PM »
I thought of something similar the other day.  to figure the air requirements of the motor, wouldn't you use displacement x rpm x volumetric efficiency? Ignoring VE for a bit, you get 750 x 8000 = 6000000   x .016 = 366000 /12 /12 /12 = 211.8 CFM.
Now let's find a TB that size...
Offline Geeto67
  • A grumpy
« Reply #16 on: April 29, 2009, 03:21:11 PM »
Here is a crazy idea......
the 1983 gpz1100 is FI, and can be used to retrofit kz1000s to FI. Dynoman sells manifolds to adapt kz1000 carbs to cb750. I have no idea if the bore spacing is right but theoretically the gpz1100 should have the same spacing for the kz1000 which means you might be able to use those throttle bodies as a bolt on. However, the gpz FI has all sorts of weird sensors like air temp sensor, and is also an antiquated piece of kit.
another crazy idea would be to use the cyclexchange 2 into 1 kit and the throttle bodies off a new triumph bonneville. These are not direct port injection so there is no real performance advantage over a carb but it is still more precise Fuel metering than a carb could ever do. Besides the point of FI is not more power, it is smoother running and operation and less maintenance - lot of people forget that.
the triumph's FI looks like carbs so it would still have a vintage look:
Offline Geeto67
  • A grumpy
« Reply #17 on: April 29, 2009, 03:23:18 PM »
I think the nissan sentra Sr20 throttle body flows 220cfm....is that close enough?
Offline HavocTurbo
  • Can you tell?
« Reply #18 on: April 29, 2009, 03:25:18 PM »
I think that might work Geeto.
09 XL883L - No Name
Offline MJL
« Reply #19 on: April 29, 2009, 03:45:24 PM »
[img width=600 height=399]http://z.about.com/d/motorcycles/1/0/i/c/-/-/09_Triumph_Bonneville_FI_BJN.jpg[img]
All you really need from the bike is the throttle bodies and maybe the fuel pump. In my EFI research it seems the ECM operates from a set of variables that tell how much fuel to give when. In other words, one could program a computer to squirt x amount of fuel at X rpm.  I don't know much about 'Squirt. Most of my knowledge has to do with the GM TBI and TPI.
One of my concerns is the engine temp sensor. I don't know what to do about that since most cars and trucks have them in the coolant, and we are dealing with air cooling. Maybe it could be plumbed into the oil return line and work?
Sounds good, but the number I gave is for the whole motor. Would you build a 4-1 intake manifold for that, or try to adapt a CycleX 2-1 intake?
Injectors, bungs, fuel rail, etc.
http://www.racepartsolutions.com/products.asp?cat=108
Offline Geeto67
  • A grumpy
« Reply #20 on: April 29, 2009, 04:46:12 PM »
I had a long conversation once with a guy who worked at summit and built an FI system for his 1968 Dodge Charger. The fruit of this conversation was that to get the best air charge from a single throttle body it pays to have a plenum or chamber. Think about all the FI performance cars you know and their fuel injection - they all have this chamber (the GM TPI from the 1980s is probably the most visible and easy to visualize). Using the Cycle Ex 2 into one intake manifolds - have them terminate at a sheetmetal box and the throttle body on the other side. You can mount the Throttle body any direction along that box it does not matter because the engine will still be drawing air from the plenum.
Something people forget about individual throttle bodies - you still have to syncronize them. It is basically the same procedure as with a carb but people often forget it needs to be done. With a single TB, what is there to syncronize?
On the TI racing FI thumper racebike they substituted the water temp sensor with an oil temp sensor which are commonly available at any speed shop. Basically you just change the temp range in the computer and you should be set. I don't like ambient air temp gauges because they are less consistent and really all you need the temp sensor for is so the motor knows if the engine is hot or cold.
Offline MJL
« Reply #21 on: April 29, 2009, 07:34:42 PM »
Air temp sensor helps the ECM compute air density, but isn't really needed. GM used it on caprices and eliminated it on trucks of the same year.  ???
I do like the Triumph throttle bodies. I wonder if they would fit in the carb boots?
As for the intake, those long 2-1 manifolds should help with low end torque, but then again they are long and adding a throttle body to it just makes it bigger. there isn't much room to start with. I'd think it would be better to put the injectors close to the head and just have a throttle plate with a tps sensor somewhere else.
I think we should start with a high output alternator first.
Offline Soos
« Reply #22 on: April 29, 2009, 07:39:50 PM »
Has anyone found a small car alternator that could be run off a pulley where the rotor currently resides?(and squeeze the alternator under the carbs?)
Is that what the ARD megneto setup basically was?
l8r
-=≡ Soos ≡=-
Offline KB02
« Reply #23 on: April 30, 2009, 04:31:06 AM »
Another thought I had to add in EFI, was to switch all of the lights to LED. Would save enough juice to to keep an EFI running in stop and go traffic? I'll admit I'm no whiz in the electronics dept.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
« Reply #24 on: April 30, 2009, 08:06:09 AM »
Well thats enough to put me off EFI...
 sounds like mechanical is bulletproof, and way quicker to set up..
