Author Topic: New CB400f - and lots of questions  (Read 2627 times)
Offline obrut
« on: April 28, 2009, 04:47:22 PM »
hi all,
just picked up a 76 CB400f (it replaces Yamaha SR500 which nearly shook me to death).  here's a pic of the new machine.  pretty honest old bike, starts first pop and with only a few issues to sort out (needs new tyres, new speedo cable, no low beam).
ok, here are the questions:
1.  bike has hi beam but not low beam - where would you start looking to reftify this?
2.  i am a big fan of the heiwa bikes ( http://www.heiwa-mc.jp/dotnetnuke4/tabid/61/Default.aspx ) and plan to mod the bike in a similar way.
are there any smaller tanks that are an easy/natural fit on a CB400f?
how do you remove the CB400f tank?
3.  compared to other bikes i have ridden, this bike has a heavy clutch lever.  is this normal?
thanks in advance for the help.
cheers, ryan
Offline kghost
Re: New CB400f - and lots of questions
« Reply #1 on: April 28, 2009, 04:50:57 PM »
hi all,
1.  bike has hi beam but not low beam - where would you start looking to reftify this?Check the bulb first then the wiring in the headlight then the control switch
are there any smaller tanks that are an easy/natural fit on a CB400f? CB350F is an exact fit
how do you remove the CB400f tank?Remove the rubber at the back of the tank next to the seat. Then it pulls off aft..off the front mounts
3.  compared to other bikes i have ridden, this bike has a heavy clutch lever.  is this normal?No. Lube the cable or get a new one
cheers, ryan
Stranger in a strange land
« Reply #2 on: April 28, 2009, 05:11:18 PM »
This post should probably be in the SOHC/4 Bikes forum, and NOT the build project forum.
Offline obrut
« Reply #3 on: April 28, 2009, 05:19:28 PM »
kghost - many thanks.  is a separate bulb used for hi and lo beam?  if not, can the lo beam filament fail independantly of the hi?
CB750 Cafe Racer Fan - apologies, i'm new to this.  if i reply with a mod will that make it a project?
Offline kghost
« Reply #4 on: April 28, 2009, 05:24:00 PM »
Its a sealed beam with independent Low and HI....
Generally they fail independantly....usually low is the one to go...because its on the most.
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #5 on: April 28, 2009, 05:26:35 PM »
Nice lookin' bike you have there.
Yeah, both beams are sealed in one 'sealed beam bulb'. Usually low fails first since it is used the most, then that broken filament usually finds its way onto the other one and blows it too  :D.
Gallery at:
