Author Topic: Clutch?  (Read 639 times)
whodareswins
Clutch?
« on: April 29, 2009, 03:59:25 PM »
 I just put my clutch back together. I have done the adjustments like the service manual says the problem is when I pull the clutch lever in it wont disengage the clutch putting the bike into neutral.Any ideas?
Offline kghost
Re: Clutch?
« Reply #1 on: April 29, 2009, 04:02:23 PM »
Couple......
First make certain the clutch is engaged.
Second make sure the cable is moving the appropriate amount at the cover under the engine.
Did you by any chance do anything to the swash plate under the cover?
The one with the balls in it?
Stranger in a strange land
Offline hapakev
  • Your Standard
Re: Clutch?
« Reply #2 on: April 29, 2009, 04:43:38 PM »
did you replace the plates? did you oil them before you installed them?  how is the adjustment at the clutch cover?
Smoking Jack
1978 CB750F(ish)
