Author Topic: Newbie question #3042  (Read 1385 times)
Offline Lenny55
« on: April 29, 2009, 05:31:37 PM »
So I turned off my bike today, smelled gas, and looked around in time to see a pretty good stream of gas draining from the #4 carb.  What does this mean?  Is it normal.  Thanks, Lenny.
'73 CB500
Offline Johnie
Re: Newbie question #3042
« Reply #1 on: April 29, 2009, 05:33:30 PM »
Not normal...carb #4 float stuck open a bit.  Give the float bowl a few taps with a plastic hammer to see if it frees up.  A regular hammer you chance cracking the float bowl.  Be sure to turn off the gas at the petcock or it can continue to drain.
« Last Edit: April 29, 2009, 05:35:43 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #2 on: April 29, 2009, 05:34:31 PM »
it means you didn't stop and let it go pee before you left.
  • Like a well oiled
    • Undead Asphalt
« Reply #3 on: April 29, 2009, 05:40:48 PM »
you can use a screwdriver handle to tap on them, cause its hard to find a plastic hammer ;D
pull the bowl and floats, and have a look-see for any junk in the fuel inlet you might spray down the disassembled carb bottom before you put it together, just for good measure.
Offline Derby City
« Reply #4 on: April 29, 2009, 06:23:24 PM »
When that has happened to me I just unscrewed the drain screw in bottom of the bowl, and hoped that any foreign object that might be messing with the floats would come out with the gas.  I think draining the gas in the float bowl also allows the float to quit floating, creating float movement...just like hitting it with a hammer accomplishes.
Done it twice so far, worked both times.  I would never hit my bike with a hammer.  I love my bike!!!
1974 CB 550
Offline moham
  • .fnord.
« Reply #5 on: April 29, 2009, 06:29:54 PM »
Not even a plastic hammer?
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
Offline Joel
« Reply #6 on: April 29, 2009, 06:37:19 PM »
Where are the first 3041 questions?
  • Like a well oiled
    • Undead Asphalt
« Reply #7 on: April 29, 2009, 07:11:20 PM »
they're on your ignore list  ;D ;D
« Reply #8 on: April 29, 2009, 07:18:12 PM »
I had this problem after the coating on my tank failed to properly cure.  A in-line fuel filter is a good safeguard, as well.
  • Like a well oiled
    • Undead Asphalt
« Reply #9 on: April 29, 2009, 07:25:08 PM »
oh don't start the in-line filter deboccle again
Offline Lenny55
« Reply #10 on: April 29, 2009, 09:27:44 PM »
Thanks guys, I'll try the plastic hammer/screw driver fix.  I'm finding out that a 36 year old bike that hasn't seen the road in a couple of years is going to need a little tweaking.  This forum is awesome by the way.
'73 CB500
Offline Johnie
« Reply #11 on: April 30, 2009, 06:20:55 AM »
And remember...all that tweeking is fun.  ;D
Oshkosh, WI  USA
