Author Topic: Carburetor Gasket Set Question  (Read 1416 times)
Offline blake255
  • Look Out! I'm about to crank this thing!
« on: May 02, 2009, 11:52:54 AM »
I recently rebuilt the carbs on my ’72 750 K2.  I purchased the carburetor gasket set 16010-300-305.  I had a rubber washer left over from every pack.  It’s the smallest one located at the bottom of the picture.  I couldn’t identify it in the parts fiche.  I’m wondering if this gasket set may be universal for a few different models of carbs.  Any help would be appreciated
1970 CB750 K0 Project 1
1969 CB750 Sandcast Project 2
1969 CB750 Sandcast Project 3
2009 Yamaha YZF R6
Offline Bill/BentON Racing
    • BentON Racing
Re: Carburetor Gasket Set Question
« Reply #1 on: May 10, 2009, 06:58:49 AM »
I think it goes on your drain plug for float bowl.Bill Benton
BentON Racing Website
BentON Racing Facebook
Offline Johnie
« Reply #2 on: May 10, 2009, 07:54:40 AM »
I saw that same kit.  The drain for the float bowls have a crush washer on the early CB750's.  But the rubber may have been used on newer models.  I have 4 extra ones too.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline blake255
« Reply #3 on: May 11, 2009, 06:04:36 AM »
Thanks guys.  I'm thinking float bowl drain plug as well.  I used the crush washer because that's what was on there when I rebuilt the carbs.  I think I'll put these on eBay now as "NOS Sandcast gaskets" :)
2009 Yamaha YZF R6
Offline Bodi
« Reply #4 on: May 11, 2009, 03:11:16 PM »
Airscrew?
Offline blake255
« Reply #5 on: May 12, 2009, 07:53:29 PM »
Tried it on the airscrew.  It actually fit, but when I put the screw back into the carb, it wouldn't seat correctly.  So I'm ruling that one out unless someone wiser chimes in.
2009 Yamaha YZF R6
Offline Johnie
« Reply #6 on: May 13, 2009, 05:19:58 AM »
No washers on the early air screws.
Oshkosh, WI  USA
Offline codyman
« Reply #7 on: May 13, 2009, 09:25:06 AM »
I just rebuilt the carbs on my '78 and there's an o-ring in each kit for the the accel pump.  There's only one accel pump, so 3 of the 4 kits had an extra o-ring.
