Author Topic: starting motor safty unit  (Read 900 times)
Offline 6adan
« on: May 03, 2009, 10:45:31 AM »
I just picked up a 76 750 rolling chassis with engine and carbs. only. It had no wiring so I got a old harness at a junk yard and just want to get it to run. From what I can tell the safety swatches from clutch and neutral go threw this starter safety switch. Can I bypass this because I have no clutch switch.I have been looking in FAQ but cannot find what I am looking for. Like I said all I want to do now is to get it to run before I do anything else. Thanks for any help in advance Dannie
1970 CB750 JDM,1975 GL1000, 1979 GL1000, 1979 CBX, 1995 GL1500, 2000 GL1500CT Valkyrie, 2008 GL1800 Trike.
Offline mrbreeze
  • Not your average
Re: starting motor safty unit
« Reply #1 on: May 03, 2009, 10:59:54 AM »
Its easy to by-pass but I don't have a book in front of me to tell you which wires.I run Yami 650 controls and don't have the clutch switch. If you look at a wiring diagram,you can see the 2 wires to the switch. Just connect them together and thats it.Just make sure you are in nuetral or have the clutch in when you start up.
MEMBER # 257
« Reply #2 on: May 03, 2009, 11:15:52 AM »
You just need 12v to the coils to make spark.
No safety unit for that.
If you want the electric start you just need to get 12V across the solenoid small wires to get it to activate.  That's what the SMSU prevents until switch condition are met.
Offline Head
  • JUST SOME OF THEM- I WAS BUILDING THESE WHEN NEW
    • My Bikes
« Reply #3 on: May 03, 2009, 08:14:37 PM »
A jumper wire between the two wire ends in the head light bucket is all you need, from the switch one wire is green with a red stripe,the other is green,both are male ends. Make a jumper wire,male end + male end for the green wire with red stripe,about 4" to 6" long
and find the wire coming into the head light bucket from the main wire harness,green with red stripe,female end,and connect that wire to one of the green connectors.
Works for me.   Head
1970x2,71,72,74,75K's,75F-FO-750ss, 2 x 75 GL1000, 77 GL1000,  3x 1981 CB900F, 74 550,  1966 CL77 305, 1967 CL77 305, 1974 MX360 Yamerhamer, 1983 CB1100F RED
NOTICE Due to current financial restraints the
Light at the end of the tunnel will be turned off until further notice!! sohc member#1522
Offline mrbreeze
  • Not your average
« Reply #4 on: May 03, 2009, 08:17:29 PM »
How's that for service Dannie??
MEMBER # 257
Offline 6adan
« Reply #5 on: May 03, 2009, 08:50:25 PM »
mrbreeze the service is great,thanks everyone. I got it to fire with some brake cleaner in the intakes,so now to clean the carbs and put on some pipes and get to run for more than a second.
Dannie
Offline mrbreeze
  • Not your average
« Reply #6 on: May 03, 2009, 10:42:26 PM »
Sounds good to me Dannie!!!....enjoy 8)
MEMBER # 257
