Author Topic: Finished 17" front wheel, now have brake mounting issues (pictures included)  (Read 6213 times)
Offline drdreas
  • 77' CB750k
I've spent the last few weeks converting my front and rear wheels to 17" rims. I laced a 4.5 x 17 harley rim to my stock rear hub, and laced my stock 2.5 x 17 rear rim to the stock front hub. Trued the wheels myself, had 150/70-17 roadriders mounted to the rear and 120/80-17 mounted to the front.
Today I went to mount the wheels, started with the front, and found that I may have brake caliper fitment issues that I did not anticipate. Here is the bike with the new wheel mounted, and the brake caliper removed.
It seems the rim is now right at the same level as the caliper mounting bracket, with only a small gap between caliper and rim.
Also, now the spokes seem to be very close to the disc, to the point that I don't think the caliper will fit down over the disc without interfering with the spokes.
I'm thinking about installing a spacer between the wheel and the disc to push it away from the spokes, It seems like I could shift the disc about 1/8" without hitting the fork
Any recommendations? I'm a bit desperate because I don't have a garage to work on the bike in, and its parked in a lot on blocks where it shouldnt be. I know folks have done 17" front wheel conversions, what did they do with the caliper mounting?
Thanks for the help
Offline kghost
Looks to me like you have your disc on backwards
Stranger in a strange land
Offline kghost
In fact it is backwards.......Flip it...
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
yeah rotor is on backwards
Offline drdreas
  • 77' CB750k
THANKS So much! I've been freaking out for the past hour wondering how the hell the caliper could possibly fit. I'll flip the disc and see if it fits better.
Thanks again!
Offline Scrubs
I bet that feels good to hear that - mass relief  ;D
Offline drdreas
  • 77' CB750k
Hell yes. I'm gonna go crack a beer  ;D
Man that rim is close to the mount, you could take a little off it but not much.
Brake is reversed in pics.
An option that is not cheap or the easiest, but might llok better...
swap fork legs to 500/550... they caliper is same. but fork leg length ..  is shorter as is disc diameter to match.. it may look better.
Offline TheHun
Delete the front brake..haha joking.
looking good...id like to see a full shot once your finished
1978 Honda CB750-K
CBR F3 Coils
Kerker 4.1 Header w/ turn down
Maxi-Dwell Ignition
Foam Air Filter Pods
Superbike bars
Starter Delete
CARB CLEANING/REBUILD: http://www.wix.com/TheHun/CarbCleaning-Site
Not Running to Running, doing the work yourself= Priceless
Offline Alan F.
Unfortunately here in Massachusetts they want you to run a front brake.
  • Like a well oiled
    • Undead Asphalt
cyclex has a mini drum setup
Offline drdreas
  • 77' CB750k
Once I flip the disc I think that the caliper will fit, but I am concerned about how close the caliper arm is to the rim. It just happens that with a 17" rim it lines up perfectly with the caliper arm. I guess I could grind it down a little bit?
Offline Alan F.
as 754 said,"Man that rim is close to the mount, you could take a little off it but not much."
You could grind, I recommend a file. But you'd substantially reduce the strength of the mount by removing material.  There is always the possibility that you could fabricate the caliper arm mount from steel, that would give similar strength from a smaller part...food for thought.
As they say, an inch is a good as a mile. Meaning if you have any clearance at all you're OK.  The caliper doesn't know or care how close it is.  You may not be comfortable with that.
I'm concerned with this though as I have a 17" laced ready to go on a CB750K2 front end. Concerned about caliper clearance.
I'm not too proud to switch to an 18" if necessary. But that's extra $$.
Good luck.
« Last Edit: May 03, 2009, 05:06:41 PM by MCRider »
  • Like a well oiled
    • Undead Asphalt
well.... did you fix it yet?
Offline drdreas
  • 77' CB750k
Yea, I was thinking that same, even if there is only 1/8" between caliper and rim, it should be enough. I don't envision the rim deflecting laterally enough to close that gap.
I haven't flipped the rotor yet, I didnt have time, but I will tomorrow and I'll post pics when I do  :)
Offline drdreas
  • 77' CB750k
I flipped the disc and the caliper fits just fine now. The clearance from caliper arm to rim is still very tight (less than 1/8"), but it doesnt touch. It just happens that the lip of a 17" rim is at exactly the same height as the caliper arm, so the clearance is very tight. If I had gone any wider than a 2.5" rim I'd been screwed!
I'm not sure how people go wider on the front or run a 16" front wheel with the stock brake set up.
I'll post pics on monday.
Good news, hope mine is the same.
Offline Alan F.
That's good news Drdreas, Will you be able to ride it today?  It's gonna be about 65 degrees, partly cloudy, and only about 10 mph winds...  I'm gonna go look for more threads on your build, looks good.
Best of luck.
  • Like a well oiled
    • Undead Asphalt
well?
Offline Alan F.
I know, right?  This guy's in the same city and nobody's ever seen or spoken with him.  His last active date here was back in september too......
-Alan
