Author Topic: Thanks Mike Rieck..........................BIG PORT HEAD  (Read 1838 times)
Offline Jim F
  • go baby go
Here ya go guys
another master piece from Mr. Rieck.
This is Mikes stage 3 porting
Porting alone is worth 12 to 15 Hp
but going from 29mm CRs to 33mm flat slides. Who knows what the final HP is going to be
big port head  with 33mm intakes
bronze guides
Ti retainers with heavy  springs
33mm flat slides
Cant wait to get the engine run in to dyno this baby
Thanks again Mike
Jim F.
« Last Edit: May 03, 2009, 04:40:26 PM by big-jim »
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Re: Thanks Mike Rieck..........................BIG PORT HEAD
« Reply #1 on: May 03, 2009, 07:20:19 PM »
Mike the maestro stikes again. UPS is dropping mine off to Mike tomorrow. I'm looking forward to your dyno numbers with the 33's. I'm doing the 34mm valves with the 5mm stems and had planned on using 31CR's. What size pistons are you using? I know 33CR's can be adapted with available stock intake runners from Honda according to Sudco.
Jerry
Offline kpier883
  • is quite the
« Reply #2 on: May 03, 2009, 07:40:14 PM »
I noted in another thread that this is for a GS850.  Were the ports originally round and Mike changed them to the current shape with the semi D shape at the bottom?
Could you comment on the shape leading up to the valve guide?
What about the area behind the valve guide (past the guide going in from the intake side) - did you cut upward there?
74 CB750
80 CBX
82 KZ1000 K2 (LTD)
57 1/2 ton chevy
Offline Jim F
  • go baby go
« Reply #3 on: May 04, 2009, 06:17:56 AM »
You would have to ask mike the details for the shape of the ports and
the reasoning behind this, But based on the engine size
which is an 840 kit with 10.5 compression
the cams have a 390 lift
and the carburetors he came up with the best shape for the ports to maximize flow
He said that based on the shape of the ports
that the head alone is worth another 12 to 15 Hp alone
The dyno will follow as soon as the motor has a good run in
