Author Topic: Kawasaki 454 LTD...info needed  (Read 7707 times)
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« on: May 04, 2009, 03:52:58 PM »
Hi all.
A 1985 Kawasaki 454 LTD arrived at my shop today....and I know little about it.
The owner brought it to me after taking it to a shop in the hopes of fixing a hard starting problem:
The owner says he had a shop check it out and found the engine has very low compression on #1, and...well.....better compression on #2.
I checked and sure enough, he was right. 30psi and 75psi
He said it would run fine on one cylinder to get it running...then once it was warm it would eventually start firing on the other. After both cylinders came online, the bike would run great...with no burning oil either?
Now, like I said, this type of bike is new to me, but I'm open for opinions as to what is going on here.
Does anyone have any experience with this type of engine (I think the 250 ninja is similar) or have any sugestions about working on it.
I suspect valves and the adjustment there of....which I have no idea how to adjust either :-\
 Matt.
Gallery at:
Offline cb650
Re: Kawasaki 454 LTD...info needed
« Reply #1 on: May 04, 2009, 05:20:31 PM »
There is a site for the kawi twins.  Dont have it off hand.  I think Ibsen (RIP) had it in his tag.
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #2 on: May 04, 2009, 07:08:31 PM »
From what I remember, the 454 was joked as "half a kz900".
Anyway you can check compression after it warms up and is firing on both? Compression that low is very bad, and the one at 35 is... wtf.
Check to make sure that both the valves are closing. Perhaps one is bent/hung up/ damaged.
No.
Offline droopy
« Reply #3 on: May 04, 2009, 07:15:46 PM »
I have a service manual for this bike if you need it pdf format ;)
2007 lifan 200cc sport ohc thumper
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #4 on: May 05, 2009, 07:10:35 AM »
I love this forum  :'( I would appreciate that Droopy! PM sent.  8)
Yeah, I haven't checked it hot yet.......35 psi is a joke to begin with so I haven't tried to start it.
More info today....aparently its been sitting a while  :D you might be right about bent/hung up valves.
...Ill keep posting as the story unfolds.
Gallery at:
Offline Soos
« Reply #5 on: May 05, 2009, 07:58:11 AM »
Have you tried pouring a bit of oil into the cylinder(throught he spark plug hole) and re-testing the compression?
Mabey a stuck ring?
Hopefully it just needs the valve clearance set.
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline hoodellyhoo
  • CB350F
« Reply #6 on: May 05, 2009, 04:18:01 PM »
I think Hope said she had one of these bikes. Maybe she can help you some?
fuzzybutt
« Reply #7 on: May 05, 2009, 05:41:21 PM »
stuck rings could do this too i suppose, pull the spark plugs and spray a bunch of pb blaster into the cylinder wait a day or so then re-do the compression test
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
« Reply #8 on: May 07, 2009, 10:55:32 AM »
Mabey a stuck ring?
l8r
+1
We do it all the time for barn fresh revivals.
The 454 is a bastard of a motor to get running right after it has been neglected. There's a whole site dedicated to them but I think it's all in dutch or finnish... crazy those dutch.
Chances are the rings are really dry and need to be sealed back up.
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
Offline droopy
« Reply #9 on: May 07, 2009, 07:13:02 PM »
it's on it's way with a few other files related to the 454ltd ;)
Offline HavocTurbo
  • Can you tell?
« Reply #10 on: May 08, 2009, 09:13:52 AM »
Oh wow. THERE'S an interesting take on a 454. Nice.
09 XL883L - No Name
Offline droopy
« Reply #11 on: May 08, 2009, 07:39:32 PM »
thanks only wish i still had it  :'( :'( :'(
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
Re: Kawasaki 454 LTD...info needed (update..problem solved)
« Reply #12 on: May 08, 2009, 07:42:04 PM »
Hey folks,
Had a chance today to finally get at the bike...and low and behold the valves had never been adjusted...ever.
Original glue on the head cover. Not the blame the PO's since it's a real pain to do compared to our sweet Honda Fours  :D
All Four of the intake valves had zero clearance with slight pressure on the valves.  ::)
Set them all up and bam...compression back to normal.
 Cheers, Matt.
Gallery at:
Offline droopy
« Reply #13 on: May 08, 2009, 07:43:26 PM »
 ;D
i see you liked the other files I sent makes valve adjustment easy compared to book
« Last Edit: May 08, 2009, 07:45:38 PM by droopy »
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #14 on: May 08, 2009, 07:48:41 PM »
;D
Definately  :D
Gallery at:
Offline droopy
« Reply #15 on: May 08, 2009, 07:52:34 PM »
http://ltd454.proboards.com/index.cgi? heres a link to a message board for the 454ltds
