Author Topic: Handlebar Wiring Clubmans K4  (Read 3218 times)
kmenzel
« on: October 30, 2005, 07:41:36 AM »
How in the %$&% do you get the wires through the clubmans turn.  I tried for a while and have pretrty much give up.  I am going to think about other switches unless someone has a great idea?
Offline mrblasty
  • Expertly
Re: Handlebar Wiring Clubmans K4
« Reply #1 on: October 30, 2005, 09:46:00 AM »
You will meed to fish a thin piece wire from hole to hole. tie a strong piece of string to the end of the wire and pull it through the bars, tie the wiring  to the string and pull through. run the string through both handle bars first and do this with the bars off the bike.
Good luck.
I farted and made my son cry.
1973 Honda CB 750
1975 GL 1000
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #2 on: October 30, 2005, 10:11:28 AM »
i drilled holes right at the kink, and just dropped the wires out there. it puts them straight towards the triple tree where they want to be aynway. i can take a picture if you need.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
kmenzel
« Reply #3 on: October 30, 2005, 11:09:16 AM »
I did try the wire and i was able to fish a small wire through.  But, i couldnt get all the wires around the bend.  its a lot on the left side
Offline hymodyne
« Reply #4 on: October 30, 2005, 03:48:29 PM »
I don't have clubmans but i shortened my stock 500 bars down to 4 inches. I took a steel fishing leader and bent the hook flat around the two or three  longest of the wires going through the bars.I taped these and the rest tight, greased them with axle grease and pushed through until I could see the wire leader at the center hole. when I could, I got a pair of pliers on it and pulled the rest of the wire slowly through.
hym
Offline MikeDeB
« Reply #5 on: October 31, 2005, 01:53:25 AM »
I route the wires outside of the handlebars by notching the bottom of the switchgear housing.  I've done this on two 750's and works just fine (eliminates the need to fish the wires through the bars).  The switchgear housing can be notched using a Dremel tool and circular stone or cutter.  Use eye protection when doing this.  Don't use this procedure if you're doing a restoration.
Mike (Old SOHC/4 #2641)
Holt, MI
71 CB750K1
72 CB750K2
72 CB100K2
97 Ducati 900 SS/SP w/FCRs
98 Ducati 750 Monster w/FCRs
80 SR500
"Growing older is inevitable, growing up is an option."
Offline KB02
« Reply #6 on: October 31, 2005, 05:15:31 AM »
hym
That's going to be the trick that saves you if you;re going to pull them through the bars
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline justfours
« Reply #7 on: March 21, 2006, 09:48:10 PM »
try to get the wires as small as possible. if te wires cross over eachother inside the tape it will make the whole bundle thicker. On mine I used an older 750 left control with no HI/LO switch, making it only four wires. REtaped straight and tight. use plenty of lube. also dont forget to deburr holes really well.
Offline pablo78cb550
  • mmmph.
« Reply #8 on: March 21, 2006, 10:15:30 PM »
man i can't believe no one said to try it this way:
ok, get a length of string and an air hose or a good set of lungs.
tape/close up both ends of the bars, and the opposing side wire hole. leave the port that the wires are going to come out of open.
stuff the string into the hole that the wires are going to go inside of.
blow air through the bars at that hole.
the air has no where else to go but out. and guess where the string is going to come out of?
the hole you need the wires to come out of!!
ok, tie the string aroud the wires and pull them though.
ta da!!!!
Bikes in hand:
1977 Yamaha XS650
1978 Yamaha SR500 #119!
1978 Yamaha XS400
1978 Honda CB550K
1965 Ducati Monza 250
Sold off:
1992 Yamaha FZR600
1981 Yamaha Seca 550
Offline Raul CB750K1
« Reply #9 on: March 22, 2006, 01:45:16 AM »
Have you tried a brake cable? (a bicicle brake cable or gear shift cable -thinner- could do too)
Also, lots of grease. dishwashing liquids helps a lot when it comes to insert cables in wall conducts, don't ask me how I know.
Raul
Offline crazypj
  • I'm brill, me
« Reply #10 on: March 22, 2006, 07:44:07 AM »
With clubman bars its much easier to fit wires straight out the end and fit grommets to stop water getting in. I've never seen anyone fit wiring through the centre section (maybe the bars I fitted were made different, there wasnt a hole from centre to the outer?)
PJ
