Author Topic: My '81 CB650  (Read 3930 times)
Offline Hush
Re: My '81 CB650
« Reply #25 on: May 11, 2009, 09:02:49 PM »
Funny thing that Wolf, as a bike rider you will notice the morons quicker, something to do with evolution and survival. ;D
Offline CB650 Wolf
Re: My '81 CB650
« Reply #26 on: May 19, 2009, 03:32:28 PM »
I ran into one little (hopefully) problem now. Carb one is overflowing. I turned the bike on and watched it real close. It looks like its leaking from the top of the float bowl where it attaches to the carb itself. I'm thinking a bad gasket, but I just had them rebuilt. Maybe the guy doing it pinched the gasket in there???
√٧oLҒ
Offline Frankenkit
  • Industrial Strength
Re: My '81 CB650
« Reply #27 on: May 19, 2009, 05:26:00 PM »
sometimes those gaskets don't seat real well.  Oddly enough, I also had one that swelled or something... OEM gasket. It developed a 'burp' in the o-ring and wouldn't settle into the groove at all, being probably 1cm too long (!) so I replaced it with one of my keyster gaskets and no problems.
In a real pinch, you could use a TINY thin layer of a GAS PROOF sealant/gasket goo to seal it up. I really stress those three words because any extra might get sucked into your jets (because carbs hate people and will do that crap on purpose) and 'fuel resistant' only means like "until you get the carbs on".  I had 2 extra rebuilds for those reasons. ::)
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline Hush
Re: My '81 CB650
« Reply #28 on: May 19, 2009, 08:47:00 PM »
Are you sure the float on that carb hasn't just jammed momentarily? many say tap on the side with end of screwdriver but as Kit pointed out....carbs hate us so tehy will probably fall off or break just to freak you out.
I prefer to put all the drain tubes into a clear jar then release the drain plugs on all the carbs and see what turns up in the jar.
Tighten your drain plugs and then turn the gas back on, this seems to work for me when my floats jam.....which they haven't done for a while cos I talked to them real nice and bought them new isolators from Soos.
