Author Topic: will 750k bowl gasket fit a 750F?  (Read 616 times)
Offline cudjo
  • CUDJO
« on: May 07, 2009, 07:19:27 AM »
Hey everyone,
I am about to clean my carbs, and I was looking for new bowl gaskets. I have a 78 750F.
I have found several kits and gaskets for the K bike but none that specify "F".
can I use the K gasket?
BTW, want to change the gaskets when cleaning right?
Offline cudjo
  • CUDJO
Re: will 750k bowl gasket fit a 750F?
« Reply #1 on: May 07, 2009, 08:00:32 AM »
Found some F gaskets!
would still like to know if I should change the gaskets no matter what?
or if I should look for some level of wear?
Offline BeSeeingYou
« Reply #2 on: May 07, 2009, 08:26:45 AM »
I don't know what everyone else's experience has been but my 76F has the original gaskets and I have had the bowls off a few times and they do not leak. Same thing with my XS650. I have had the bowls off several times in the course of 29 years and the original gaskets do not leak.  From a few things I have read here sometimes the new gaskets are crap and may leak worse than the old ones.  With an OEM kit they are probably ok but a cheap knock off who knows.    I suppose if you are going to the trouble of dismounting, disassembling, and cleaning the carbs it may be better to use the new ones.
« Last Edit: May 07, 2009, 09:17:30 AM by srust58 »
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #3 on: May 07, 2009, 09:27:45 AM »
Gasket sets would be based on carb model.  If K and F use the same carb, then they would interchange just fine.  An even better check would be to use a parts fiche to compare part numbers.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
