Author Topic: Do I sell this or get it fixed (video added 5/11)  (Read 5761 times)
Offline super pasty white guy
  • I'm not really a
  • 1976 750 F
Re: Do I sell this or get it fixed
« Reply #25 on: May 07, 2009, 07:36:06 PM »
I know, it's a bit overwhelming (I was there- refused to remove the carbs for a year).
Look at it this way, you've done it once, you can do it again.  And it'll be easier the second time around.
But if you don't start at the beginning, you'll just be chasing your tail.
Go and do a search for shimming the points plate (might be in the faq).  That'll make life easier when timing.
The advancer mechanism is the shaft that the points ride on, the weights are on the back side of the plate that you can't see.
the carbtune is attached by removing the brass screws on the carbs.  Check out the manual, it'll save you a lot of grief.  Though doing a carb sync is kind of pointless unless everything else is running well.
spwg
Offline Johnie
« Reply #26 on: May 07, 2009, 07:38:26 PM »
Here is a pic of 2 of the 4 vac. ports on my 750.  Probably about the same on yours.  Remember, sync is the very last thing you do.  After points, plugs, valves, timing, etc.  Then do sync last.  And not to scare you, but read up on it or you could take a nice running bike and make it worse.  Best of luck and remember, this is fun!!! ;D
« Last Edit: May 07, 2009, 07:41:57 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline andy8190
« Reply #27 on: May 07, 2009, 07:40:04 PM »
yep i found the ports right after i posted that. so let me search that shimming
Offline Johnie
« Reply #28 on: May 07, 2009, 07:43:05 PM »
Justs don't mix the vac ports up with the air screws.
Oshkosh, WI  USA
« Reply #29 on: May 07, 2009, 07:44:00 PM »
Sounds like you never read the manual & familiarized yourself with the process.. BEFORE PICKING UP TOOLS!.. and are now relying on us to explain what you should know before you even start..
You can check advancer by seeing if it snaps back, turning it manually.
If you static timed it according to manual, it should run down the road and work.. & when you put the light on, be reasonably close..
Offline andy8190
« Reply #30 on: May 07, 2009, 07:46:43 PM »
no i did read the manuals except the shop manuals that i have for the 550 all are missing the page that shows how to connect the sync tool.
And as for timing i did read a all the manuals i have and they didnt make clear since to me. Sorry if that is a burden to some people, but thank you very much to the people who are offering help. Trust me i have tried to do this without help.
Offline andy8190
« Reply #31 on: May 07, 2009, 08:20:23 PM »
ok the advancer doesnt seem to be stuck and i cleaned it anyways, gonna put it back on and tackle timing again.
Offline ev0lve
« Reply #32 on: May 07, 2009, 08:25:29 PM »
Not much to add here except
Offline andy8190
« Reply #33 on: May 07, 2009, 08:28:30 PM »
haha ohhhhh myyy. So i just discovered since i cleaned the points cam now i need to lube it and guess what...... i dont have any lube, what can i use?
Offline ev0lve
« Reply #34 on: May 07, 2009, 08:31:15 PM »
Did mine with some moly lube I had leftover but points cam grease (which I couldn't find). Any type will do in moderation is what I've read.
Offline andy8190
« Reply #35 on: May 07, 2009, 08:33:00 PM »
would it be ok to put it back on tonight and lube it sunday? i found threads answering that question about lube to use.
Back to advance timing though, if this didnt fix the problem and i still cant get it to advance what should i do? I read a thread that said its better to have the bike fire at the right advance timing than it is the idling time. What do you guys think about this?
« Last Edit: May 07, 2009, 08:35:21 PM by andy8190 »
Offline ev0lve
« Reply #36 on: May 07, 2009, 08:35:21 PM »
Oy. That I don't know. I would think for the purposes of tuning it there wouldn't be a problem but let some of the guys who know for sure answer that.
Offline andy8190
« Reply #37 on: May 07, 2009, 08:57:56 PM »
some of these manuals instructions are so damn vague. When setting the gap for the points are you supposed to eyeball it or is there a indicator that tells you when the gap of the points is at its widest
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #38 on: May 07, 2009, 09:15:34 PM »
two words man, "dyna ignition"
and two more "headache over"
  • Like a well oiled
    • Undead Asphalt
« Reply #39 on: May 07, 2009, 09:16:53 PM »
i forgot these  ;D ;D ;D ;D ;D
Offline ev0lve
« Reply #40 on: May 07, 2009, 09:19:49 PM »
My manual says by eye. Rotate through until you can tell where the points are fully open then hit it with the feeler gauge and adjust the points to that.
Offline andy8190
« Reply #41 on: May 07, 2009, 09:30:59 PM »
ok set the points gap and all cylinders are at the f mark at 1000k, but i still cant quite make it to the advance marks on any of the points. Is this mean i need new points and what not, or is there another problem. I dont mind buying them. I am gonna get the hondaman set up when i do though.
on a happy note though my bike sounds so much better at idle, no knocking
Offline coyotecowboy
  • Easily Distracted
    • American Legion Riders Post 69 Medicine Lodge, Ks
« Reply #42 on: May 07, 2009, 09:58:57 PM »
Ummm....what manual are you using?  The Honda manuals make everything pretty clear, I always use mine then go here for the "updated" service tricks :D
When all else fails, get in touch with Mark (Hondaman).  He really knows his #$%* about these SOHCs.
The adventure begins when things stop going as planned - Glen Heggstad
http://www.alrpost69.com/
Sunrise Orange 750 K2
1981 Husqvarna 430 XC, "Inga"
Offline andy8190
« Reply #43 on: May 07, 2009, 10:04:12 PM »
see the honda manual i am reading doesnt say anything about how to adjust the advance timing just the idle timing, the honda shop manual for the 550 that i have is missing like 8 pages
« Last Edit: May 07, 2009, 10:05:47 PM by andy8190 »
Offline Johnie
« Reply #44 on: May 08, 2009, 06:36:53 AM »
Andy...you been doing so much tinkering and it sounds like you are pretty close now.  Don't get to picky with the idle thing.  Take it out and ride it.  See how is runs and this might be as good as it gets.  You have to give these bikes a little slack.  Ride it and let us know how she runs...
Oshkosh, WI  USA
Offline andy8190
« Reply #45 on: May 08, 2009, 08:11:49 AM »
so i got on here after i was all done last night at like 3am and she seemed to run retty well so i think i am dont with the tuning up. wont be able to really ride here for a while bc it is suposed to rain for like 4 days. i think i am going to go ahead and order new points and stuff, and go with hondaman ignition. i poster another thread about an oil passage cap if anyone has thoughts on that
  • Easily Distracted
« Reply #46 on: May 08, 2009, 07:49:34 PM »
Don't worry about adjusting the advance, you just need to verify that it is working.  And there are manuals available here for download for your specific model.  I think they're stickied at the top of this very sub-forum, actually ;)
Offline andy8190
« Reply #47 on: May 08, 2009, 09:16:48 PM »
yeah i downloaded all the manuals for my model but i have looked through them all and i cant seem to find anything on the advance timing adjustment just the idle one.
  • Like a well oiled
    • Undead Asphalt
« Reply #48 on: May 08, 2009, 09:20:05 PM »
don't worry about it man, I run a little advanced, just for good measure.
Offline andy8190
« Reply #49 on: May 08, 2009, 09:24:01 PM »
exactly what do you mean "little advanced"
