Author Topic: CB500 Clutch Cover Removal  (Read 1309 times)
Offline stevenmgrr
« on: May 09, 2009, 11:08:02 AM »
Ok, I give!  What is the trick to removing the clutch cover on a 71 CB500.  I have removed all of the screws but for some reason I cannot break the seal to get the thing off.  I have hit it several times with a rubber mallet.  I don't want to try to pry it with a screwdriver.  Any tricks?
'71 CB500 K0
Offline scooter1
  • 1973 cb750
Re: CB500 Clutch Cover Removal
« Reply #1 on: May 09, 2009, 12:05:37 PM »
Are you talking about the cable side cover or the actual clutch cover...right side crank case.  If its the right side just use a rubber hammer give it a few taps it should come loose. Keep in mind there are two dowel pins which keep the cover in line.
Offline burmashave
  • Forum Immoderator
    • burmashave.net
« Reply #2 on: May 09, 2009, 03:43:31 PM »
And try hitting it from all sides.
Quote from: SOHC Digger, RIP
'77 CB750k
