Author Topic: Oil leaking out of points cover...Crank seal?  (Read 859 times)
GodFather13
« on: May 13, 2009, 07:33:34 AM »
Well, I knew it was too good to be true. I had everything on the bike working perfectly. No leaks, no issues. I go to clean the bike I notice a little oil seaping from the bottom of the points cover. I removed the cover and see a small puddle inside the housing at the bottom. Not a lot, but its there. I have a dynatek, no points in there.
Im assuming the only thing it can be coming from is the crank seal right? Its the original one so I guess 30+ years and 38,000 miles is a good life. Anything else it could be?
Im also assuming the engine has to be removed to replace this one seal, correct? Should I wait to do this when its really bad, or bite the bullet and do it soon? And if I do it, should I go ahead and tackle anything else while its apart?
Thanks in advance!
Offline Deltarider
Re: Oil leaking out of points cover...Crank seal?
« Reply #1 on: May 13, 2009, 07:44:59 AM »
Why worry? Just clean it up every now and then. Next oil change consider trying Castrol GTX 15-40 High Mileage that helps stopping leaks. (Or Castrol GTX Diesel 15W-40 which is the same oil, at least on our market). Worked for me.
« Last Edit: May 13, 2009, 07:54:14 AM by Deltarider »
CB500K2-ED Excel black
« Reply #2 on: May 13, 2009, 08:51:45 AM »
there is a small "O" ring on the stud the advacer fits to that can leak
