Author Topic: Oil leak from???  (Read 1902 times)
Jim Shea
Oil leak from???
« on: November 01, 2005, 07:57:20 AM »
Nice day today here in the UK so I went for a 30+ mile ride, reached top speed of 80 mph very briefly, but mostly max 65 mph.
Problem is: when I looked at my left boot(bridge of foot area) there were visible signs of oil on it. There does not appear to be any oil dripping when stationary.
I have just changed, oil & oil filter and plugs. The bike seems to be running well.
Any ideas?
Offline Bob Wessner
  • "Carbs Suck!"
Re: Oil leak from???
« Reply #1 on: November 01, 2005, 08:02:59 AM »
There are a couple of sources. First could be the shifter seal. It leaks and some oil finds its way down the shifter arm and on to your shoe. Try wiping under the shifter arm with a paper towel after a ride and the bike has been sitting overnight. The other is possibly a leaking alternator gasket. I have both issues myself and hope to tackle them this winter.
Jim Shea
« Reply #2 on: November 01, 2005, 08:28:50 AM »
Bob,
Cheers, there doesn't appear to be any oil coming from the shifter area. I think that the high-ish  speed may be relevant in this mystery, as this has not happened before?
Jim.
Offline Einyodeler
  • Midnight bugs taste best!!!
« Reply #3 on: November 01, 2005, 08:47:02 AM »
Do you notice any oil around the filter area or the fins ?
Clean off all of the oil  then spray the motor with some white athletes foot powder in a can.Take it for a ride and after that you`ll be able to see where the oil is originating from by following the telltale tracks of the oil in the powder ;)
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
Jim Shea
« Reply #4 on: November 01, 2005, 08:51:29 AM »
Great idea;  no sign of any oil on the fins or around the filter cover.
Btw, how is your athletes foot?  :)  Would talcum powder work the same ;)
Offline Einyodeler
« Reply #5 on: November 01, 2005, 09:15:24 AM »
Me , an athlete ? Ha !
 My soccer days are over , hip and knee replacement following a bad bike wreck :-\
The spray on powder works better because it will still stick at speed.
« Last Edit: November 01, 2005, 09:20:06 AM by Einyodeler »
Jim Shea
« Reply #6 on: November 01, 2005, 09:18:59 AM »
Sorry to hear that, at least you survived to tell the tale!
I will try that powder trick tomorrow, if it is dry!  ;)
Offline Clyde
« Reply #7 on: November 01, 2005, 07:18:05 PM »
May sound stupid, but have you checked the LH front fork seal.
Regds Clyde
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
Jim Shea
« Reply #8 on: November 02, 2005, 12:39:55 AM »
Clyde,
Cheers mate, I would not have even thought of checking that.
Jim.
