Author Topic: painting a gas tank  (Read 525 times)
Offline gerhed
painting a gas tank
« on: May 14, 2009, 07:21:01 AM »
Do you clear coat over the decal or vice versa?
          83 XL600R in CB360 Frame
Offline Chester345
  • will someday be an...
  • 76 CB750F
Re: painting a gas tank
« Reply #1 on: May 14, 2009, 07:25:06 AM »
I was talkin to a couple buddies about just that the other day.  Both did the clear coat over the decal approach.
I guess you could do both too though...
Offline 333
  • Time for change
« Reply #2 on: May 14, 2009, 07:27:42 AM »
I would.  It seems to me that it would have a better chance of staying on.  The other side of that is that you had better be happy with the decal as it would be difficult to remove it from under the clear coat.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: May 14, 2009, 07:55:33 AM »
I've done it two different ways before, but both ended with at least a couple of coats of clear over the decals.
The first way was to put the decals on the base color coat and then clear over them.  The second way was to put the decals on the first coat of clear and then a couple more coats of clear over them.  Both ways worked out well.  You need the clear over the decals to protect them from gas spills and the elements.
Offline 74cb750
« Reply #4 on: May 14, 2009, 11:11:59 AM »
Defintiely go w/ the clear coat over the decals.
Laugh at least once a day.
Life  $ucks, then you die.
