Author Topic: Can I use modern tires?  (Read 2884 times)
750K4
« on: November 01, 2005, 11:49:17 AM »
I need a new set of skins for the ol' 750K4. I'd like to upgrade to a modern tire/tread design. I'm looking at Dunlop GT501's. It's a bias ply tire with a modern radial tread pattern.
Here's the link to the tires I'm considering:    http://www.dunlopmotorcycle.com/tirecatalog_tire.asp?id=8
My question is this: Can I use a this tire (tyre?) and put a tube in it on my spoked rims?
« Last Edit: November 01, 2005, 11:54:41 AM by 750K4 »
Offline Einyodeler
  • Midnight bugs taste best!!!
Re: Can I use modern tires?
« Reply #1 on: November 01, 2005, 11:51:18 AM »
As long as it`s a bias ply and not a radial , you`re good to go.
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
750K4
« Reply #2 on: November 01, 2005, 11:59:30 AM »
So there's no difference in the shape/profile of a tube-type and tubeless tire's rim?
Offline Jonesy
  • Shop Rat
« Reply #3 on: November 01, 2005, 12:14:32 PM »
The difference I've found with bona fide tube tires vs the tube/tubeless ones is the fit on the rim. The tube type tires are easier to mount by hand, since the bead diameter is a bit more generous since it's not relying on the fit to provide a seal for the air inside.
In theory, and tubeless tire can be run with a tube, but it will run a bit hotter than one without a tube.
750K4
« Reply #4 on: November 01, 2005, 01:02:21 PM »
Excellent! Thanks for the replys, guys. I've been lurking here for a few months and finally got around to posting. What a great site!
Doug
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #5 on: November 01, 2005, 01:09:37 PM »
750K4,
I fitted tubeless tires to my K0 last winter myself. If you can, I would recommend you have someone else do them, it is a pain, if you have large hands, literally a pain.  >:(
« Reply #6 on: November 01, 2005, 05:38:00 PM »
Modern tires with a tube are okay.  I've been doing it for years.  You do need to select a tire that will be compatible with your rim internal width, though.
« Reply #7 on: November 01, 2005, 06:06:51 PM »
I put a set of Battleaxes on my 78 750. They make the bike come alive. One thing I did find was that I needed to tweak the tire presssures. These new tires have more flexable sidewalls you need a couple of pounds of air more make them go from sloppy to amazing.
Offline hymodyne
« Reply #8 on: November 02, 2005, 05:01:59 AM »
I mounted modern tubless tires on my bike, and yes, it was a somewhat of a pain. I'm running tubes and so far have had no problems.
hym
Offline dusterdude
« Reply #9 on: November 02, 2005, 06:05:36 AM »
     bobby,which battleax are you running?
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #10 on: November 02, 2005, 06:58:19 AM »
I am running Avon Venom X tires , and am more than happy with them.....
750K4
« Reply #11 on: November 02, 2005, 08:30:53 AM »
Anyone have size suggestions for replacing the stockers? I'm not looking to stuff as much rubber as I can under there, just similar-sized replacements. A little wider would be OK...
Offline Dennis
« Reply #12 on: November 02, 2005, 10:09:08 AM »
My '75 CB750F, which should be the same sizes as your K4 originally had 3.25-19 front and 4.00-18 rear. It is difficult to make direct comparisons dimensionally between "inch" and "metric" sized tires because of different profiles.
My selections were 90/90-19 front, 120/90-18 rear. The front is about as close as you will find dimensionaly to the original, the rear is a little larger. Part of the selection process was evaluating the tire manufacturers specifications on acceptable rim widths. One of my criteria for the front was not to exceed the OD of the original tire (which I could only guess at by measuring the original tire which was still on the bike).
The bike handles nicely and "turns in" very well.
You will find that most people on this forum tend to use the 100/90-19 size for the front tire. There is a wider selection of tires in that size. The 110/90-19 is generally considered to be too wide (it is certainly too wide for the stock rim) and supposedly results in slow handling. I have not tried this myself, so I cannot say from personal experience.
Selections of rear tires vary considerably.
750K4
« Reply #13 on: November 02, 2005, 01:57:06 PM »
I was actually looking at 100/90-19 for the front and 120/90-18 for the rear. Sounds like they will fit fine. I guess I was concerned they'd interfere with the fenders, brajes, etc.
Thanks everyone.
Doug
Offline Dennis
« Reply #14 on: November 02, 2005, 04:53:40 PM »
Thanks everyone.
Doug
You will be fine with that.
But why didn't you just say what sizes you wanted up front? You would have saved me a lot of typing, and I HATE to type!!!! :P
Offline Uncle Ernie
« Reply #15 on: November 02, 2005, 06:04:12 PM »
My experience; the closer you keep to the original size, the better it will handle in turns.
Offline dpen
« Reply #16 on: November 02, 2005, 06:17:23 PM »
I've run Battleaxes on all my bikes for a lot of years.
Reasonable cost, good mileage & they stick like s#it to a shiny shovel.
As BobbyR siad, a bit more air pressure is needed - I run just over 36 psi in both tyres on my K7, any less than 34 & you can feel a slight difference (for the worse)
« Reply #17 on: November 03, 2005, 05:12:17 PM »
Duster I used a bias ply sport style. I would have gone retro, but I really wanted some bite on the sidewalls. I like em, as long as I keep the pressures a bit higher than the sticker, she is very stable.
amattel
« Reply #18 on: December 05, 2005, 02:44:33 PM »
I am running 100/90-19 in front, 120/90- 18 rear.  Dunlop gt501 bias play....  quite sticky. and the bike handles really nice...  I ran a 110/90-18 once on the rear( a metzeler me-77..  It felt much less stable on the highway...  the 120 is great!  thought about trying a 130, but I don't want to have to modify the bike.
Adam
