Author Topic: torque wrenches, I don't trust them  (Read 6282 times)
Offline MoTo-BunnY
  • The 'Torque 'er Down 'till it Strips Then Back 'er Off a Quarter Turn', Type of
  • 1973 CB500 ~ member #3791
    • http://instagram.com/moto_bunny#
Re: torque wrenches, I don't trust them
« Reply #25 on: October 08, 2007, 04:54:14 PM »
If  you don't trust your torque wrench, the correct procedure is the following: Torque the bolt 'til it strips then back-off 1/16th of a turn, that should put you in the ballpark :D
I always heard torque it 'till it strips and then back it off a quarter turn. .. .but maybe that's only for Kneuten joints or muffler bearings?    ;)
---> instagram.com/moto_bunny# <---
[img width= height=]http://farm4.static.flickr.com/3440/3846213109_ae572002d4_o.gif[/img]
hoppin' on down the bunny trail . . .
1973 Honda CB500K2
1970 Ding-How aka Nova R-S w/3.5HP Tecumseh MiniBike
1970 Taco Model 22 deluxe w/3.0HP Briggs & Stratton MiniBike
1973 GMC Vandura 3/4 Ton Van (350CID V8)
1973 Dodge "Chinook" RV (360CID V8)
1985 Toyota Tercel Wagon SR5 (4WD - 3A engine)
1982 Toyota Pickup Truck (2WD - 22R engine)
1962? DriveX Pack-Mule (Tote-Gote clone)
1989 VW Jetta GLi 16V
1991 Diamondback Mtn. Bike
« Reply #26 on: October 08, 2007, 05:08:41 PM »
Scott, this may be part of the problem.
When you first crack loose a fastener, I like to go about a 1/4 -1/2 turn or so, then stop and go back & forth a bit, to allow anything stuck to the thread to release..then wind out fastener. By hand you can feel what is going on.
Threads should be clean before reassembly, and running a tap down can be helpful. Also if you beadblasted..be really sure you got it out of the thread...and everything else..
Offline Wheelhorse77
  • She's got some Juice
« Reply #27 on: October 09, 2007, 09:11:35 AM »
Scott,
   I just happen to calibrate TQ Wrenches for a living, for the last five years. I have to say if your wrench has been calibrated on at least bi-annual basis and used correctly it will not break or strip anything when the correct torque is applied for that item. One thing to think about is if the wrench has been dropped or misused it's calibration has more than likely been knocked out of whack. Also if you used any type extension, universal (angle) or crowsfoot (offset) they will need to be figured in to the equation because it will have a known effect on the torque value. You DO NOT want to lubricate, you always torque dry, lubrication will drive up the torque value on the item to which the torque has been applied. Another words torque a bolt dry to 30ft.lbs. and the TQ wrench will break at 30ft.lbs. and that is what you will have for an applied torque on the bolt. If you lubricated that same bolt even though the wrench would break saying the torque was 30ft.lbs. it would actually be a lot more than 30ft.lbs. and there is no known way to compensate for lubrication. The breaking type (click) is probably the most accurate and durable.
I disagree with the lack of lubricant in various applications. Bike head bolts or nuts require lube. Many( almost all) rod bolts insist on lubricant. Carrillo uses a heavy duty never seize compound, ARP bolts(ie Falicon rods) require either motor oil or their ARP lubricant, Crower rod bolts use moly lubricant. When it comes to aftermarket rod bolts a torque wrench isn't what you really want anyway. I use a stretch guage. The introduction of Locktite can change the torque value but many factory manuals recommend locking compounds AND put a torque value on the bolt or nut. Bottom line is follow the guidelines put forth by the manufacturer.
Are any of the after market bike parts you assemble require TTY or are you referring to assembling other automotive components that require an angle gauge?
77 750F2 ressurected from the dead
ASE Advanced Level Master Tech
« Reply #28 on: October 09, 2007, 11:02:13 AM »
I work in a Federally regulated industry and like Aircraft our Torque wrencheds need to be certified every six months. I teach torquing to our new hires. We use clicker wrenches and a few statements were made which may be partly true.
1. Every bolt has a wet and dry torque. A plated bolt has a different value than an unplated bolt since the plating increases thread dimension.
2. A clicker wrench should be stored at the lowest setting and not zero or at the last torque you used.
3. Many do not realize you need to hold the handle on the indicated spot and smoothly pull down not jerk the handle.
4. On a clicker wrench many people feel the click and keep pressing, you should let the wrench rebound in your hand at the click.
5.The maximum torque rating of a bolt should be only 80% of it's braking point.
6. One of the problems today is bogus bolts made offshore, when you buy a grade 8 it can test out between 4 and 6 and they break.
& When you torque a bolt the last two turns should be done with the torque wrench. I have observed guys hit a bolt with an impact wrench and then put the torque wrench on it.
9. I personally like using a mild Loctite on all bolts on my bike since there is vibration and it helps insulate the dissimilar metals.
10. If I am bolting into aluminum I chase the treads before I put the bolt in.
Offline canttuckmyshirt
« Reply #29 on: October 09, 2007, 11:29:14 AM »
Can anyone recommend a brand of clicker? I had a Craftsman fail in under two years (stored correctly, never dropped/abused, used 5 times). They only cover is under a 1 year warranty and don't offer a repair service. I will not buy any craftsman products that aren't covered by their lifetime warranty.
Any recommendations? Thanks!
72 CB500, Abe Henry wheels
77 CB550, resto-mod
04 S2000, LS1 V8
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #30 on: October 09, 2007, 12:29:18 PM »
       I have a Snap-On 1/2dr torque wrench that is a ratcheting clicker type that I bough new back in 71'. I've always kept it in the heavy duty plastic case and I've always backed the tension off, when not in use.  I got it checked a couple of times when I worked in a Civil Service Shop on ARMY equipment and was always within tolerance. I was told that there really wasn't much use in getting it checked too often, since I take such good care of it. BTW, it still looks like new (remember, it is a 1971' model). Every now and then I have had it checked (last time was about 4yrs ago) and it was still looking good. I use this one for most of my torquing and I've got a Craftsman 3/8"dr beam type for smaller amounts of torque (my Snap-On has a range starting at about 35ftlbs). That's my experience with torque wrench.
                                 Later on, Bill :) ;)
Member # 1969
Offline bert96
  • past ride
« Reply #31 on: October 09, 2007, 12:36:36 PM »
I have 3 torques wrench 1/4  3/8 and 1/2dr  all Proto.I bought proto because my dad(he's a mechanic)  he have one for almost 30 years without any problem.I think when it comes  to have a precise reading you should pay more for a good tool.
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
