Author Topic: 76 550F 99% done (pics!)  (Read 1905 times)
Offline Noco
  • nec spe, nec metu
« on: May 17, 2009, 06:03:32 AM »
I've been working on this bike for 2 years, enjoying this forum the entire time. I just finished redoing the topend for the second time (machining snafu) and there is finally no smoke! Having to take it apart again gave me the opportunity to polish some covers and customize the lights, so it wasn't all bad. I love it, but I'm selling it to finish my Norton (I'm asking a lot, so I'm sure I'll be able to enjoy it most of the summer)
I really like the way that the norton fork ears and signals clean up the front end on the 550F, I would like to put all the instrument lights in a Norton bucket and relocate the key under the tank, I think along with some chrome gauge covers it would really transform the front end (and do away with some plastic)
Offline babyfood1217
  • The only way to drink espresso is as a
  • I miss my baby...
Re: 76 550F 99% done (pics!)
« Reply #1 on: May 17, 2009, 07:03:53 AM »
great looking scoot!  clean and simple.
I need help moving my project bike from Wisconsin to Seattle, WA.  Willing to pay well.  Contact if interested.
SOHC member: #438
Project: 1976 CB750K
GSXR forks, Monoshock Rear end, 836 in progress, RC51 pipes, custom frame and everything else.
Offline Johnie
« Reply #2 on: May 17, 2009, 07:17:57 AM »
Yes, very nice.  Don't leave it parked there to long...whoosh....
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #3 on: May 17, 2009, 07:21:12 AM »
i dig the norton parts , it does give the front a clean , stock look  ... very nice
Offline Noco
  • nec spe, nec metu
« Reply #4 on: May 17, 2009, 12:10:50 PM »
i like that it looks stock.
It even felt stock putting it together (I took one of the rubber donuts that was in the bottom of my crunched stock ears and put it inside of the gaiter then put the hoseclamp on to hold it up, it worked out really well, and stays up better than stock)
I think the fact that the bike was mangled when I got it was kind of a blessing, so I didn't feel bad about getting creative with it. I don't think I would have rearranged it if it was a barn-fresh survivor.
Offline Noco
  • nec spe, nec metu
« Reply #5 on: May 18, 2009, 07:05:56 AM »
the threads on this forum were REALLY helpful for doing this work..
(for when I was too thick headed to understand the manual or the parts hard to find. They all made a measurable difference, IMO)
drilling clutch basket, installing new plates, adjusting clutch.
smoothing intake bores
double sprung points
tapered headset bearings
sealed wheel bearings
bronze swingarm bushings
rebuilding top end with oversize pistons/rings, (getting proper gaskets and o-rings and sealers)
cam chain and tensioner
primary chain, crankcase bearings, seals, dampers
fork seals, polishing fork tubes
stainless brake line
rebuilding caliper
rebuilding starter solenoid
rebuilding carbs (jetting for mac exhaust, float adjustment, adjusting air screws, synching, not getting pods, eliminating air leaks)
setting tappets
proper profile tires
changing shifter seal
de-rusting/painting/polishing chrome and aluminum
Offline TheHun
« Reply #6 on: May 18, 2009, 08:14:02 AM »
great looking bike.what kind of exhaust is that?
1978 Honda CB750-K
CBR F3 Coils
Kerker 4.1 Header w/ turn down
Maxi-Dwell Ignition
Foam Air Filter Pods
Superbike bars
Starter Delete
CARB CLEANING/REBUILD: http://www.wix.com/TheHun/CarbCleaning-Site
Not Running to Running, doing the work yourself= Priceless
Offline cleveland
« Reply #7 on: May 18, 2009, 08:24:35 AM »
Very nice!
Offline cafe2be
« Reply #8 on: May 18, 2009, 08:27:53 AM »
Another Brooklyn guy. There are alot of you guys in BK. Are there ever GTG or cruises around the area. I am in Queens. Nice bike. Has a awesome stock/not so stock look.
Offline dagersh
    • Photos
« Reply #9 on: May 18, 2009, 01:32:04 PM »
Same here in NYC, anyone doing any group rides/meets other than Ear Bar and Mark? Match?....  I can't remember the place in Brooklyn.
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB450/500 Custom
1972 CB500K1
1975 CB550F
1976 CB400F
1975 CB750 Future Restoration
1976 CB750K6
1976 CB750F
1976 GL1000
1968 Suzuki T500 Cobra
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline Really?
« Reply #10 on: May 18, 2009, 02:37:59 PM »
So, are you Ray?
Nice bike btw.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline r6100mph
« Reply #11 on: May 18, 2009, 03:22:25 PM »
what kind of taillight/ turnsignal set up is that!?
I like the low profile look, but still looks somewhat stock.
or is that the 550 stock setup?
Offline Noco
  • nec spe, nec metu
« Reply #12 on: May 18, 2009, 05:50:54 PM »
it's a MAC (the only all-chrome exhaust I could find for 550)
Offline Noco
  • nec spe, nec metu
« Reply #13 on: May 18, 2009, 05:55:05 PM »
I got the turn signal on ebay, I think it is Emgo or similar quality, but it does have an aluminum body that can be polished and drilled easy. I bolted on Norton turn signal that I already had. I think yu can get Norton repeo lights cheap at Rgmmotors.com, I like them better than honda cause they have a simple threaded base.
Offline Joel
« Reply #14 on: May 18, 2009, 05:58:00 PM »
I really like the look.  I'm a fan of clean and simple.  Great job!
Offline Noco
  • nec spe, nec metu
« Reply #15 on: May 18, 2009, 05:58:55 PM »
So, are you Ray?
no, Ray's 69 bonnie should be sitting there
Offline Joel
« Reply #16 on: May 18, 2009, 06:10:01 PM »
So, are you Ray?
Bonneville?
