Author Topic: 130/90/18 or 120/90/18 new rear tire on my K1, which ?, any opinions ?  (Read 9701 times)
Offline Spanner 1
I want to put new Dunlop 404's on my 750 K1, front would be 100/90/19" , but not sure about back tire, 120 or fatter 130....any thoughts, opinions ?
« Last Edit: May 18, 2009, 11:30:04 AM by Spanner 1 »
Offline swan
110/90 18's for my CB750's
1975 CB400 F cafes, 1974 CB750 K4 Cafe, 1966/1976 Triumph/ Norton Triton Cafe and 1962 DBD34 BSA Gold Star Clubman.
CB750 build http://forums.sohc4.net/index.php?topic=52551.0
Offline Inigo Montoya
From what I have heard, the earlier K bikes had narrower rims than the 77/78K. Consensus seems to be that the 110 is best with 120 the edge. Now this is for supposedly proper handling. I feel tire design effects this though. Also a 110 from bridgestone might not be exactly the same as a 110 from dunlop. Check with each manufacturer as tire tech has changed and what honda listed in the 70s may not be completely accurate anymore.
I'd say that's right. The older rims were 2.15s, max tire is 110 per the book. 120 would work, but I wouldn't do a 130 without a rim change to a 2.5.
Offline Spanner 1
Thanks, all , for the info..........
Anyone else ?
« Last Edit: May 18, 2009, 11:30:29 AM by Spanner 1 »
Offline mrblasty
  • Expertly
Too wide a tire will get "pointy" at the center of the tread which will lessen your contact patch with the road.
I farted and made my son cry.
1973 Honda CB 750
1975 GL 1000
Offline turboguzzi
+1
Offline Old Scrambler
Depending on the tire brand and profile, the 120 may touch the chainguard. The 130 will require a notch in the chainguard.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Kevin D
  • SE Michigan
I had 110 spitfire and replaced it last year with 120 battalax. No fitment or clearance problems. I have about 1/8" to the brake stay arm.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
+1
+2 been there and see it. The 110 works so much better in the corners.....lean, lean, lean....if you are only cruising down the highway and what a fit tire look go for the 120 but expect it to wear more in the center.
cheers
Andy
Offline Spanner 1
Real life answers....I love it , thanks again.................more?
Wait....110's better in the corners!, well, I'm all about that !! ( Old but sporty enough !! ).
« Last Edit: May 18, 2009, 05:30:02 PM by Spanner 1 »
Offline Gordon
  • 750K1, 550K2
I have a 100 on the rear of my K1.  I've never had any other size on it so I don't have any comparison, but this size has worked great for me.  Good wear across the width of the tire, not just along the middle.
Offline Spanner 1
Gordon, I know it's a 'fashion' issue, but does a 100 rear look really 'anemic' on a K.., viewed from the back ?
Offline Gordon
  • 750K1, 550K2
I don't think so, but then it's all I've ever seen on this bike, so it's what I'm used to.
If a 4.00 was stock that equates to 1.01 metric. So a 100 is just an unnoticable skosh smaller.
A 110 metric would be 4.33 inches, so slightly wider, but not as wide as a 4.50 which we used to run all the time pre-metric. A 120 would be 4.72in which is wider than the 4.50 we used to run, so just a skosh too wide for the rim.  Just FYI.
Offline Spanner 1
Thanks G and MC......nice pic, G.
Offline Scrubs
I run a 130 tyre on a 3" rim - no clearance issues.
Offline 333
  • Time for change
My K4 had a 130 on it when I bought it.  When going into a turn, it "fell" off of the center of the tire into a turn, and I had to work to keep it from falling into a tighter turn than I wanted.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
That would show the difference in the rims, assuming yours was stock, that's how a too wide tire would perform.
A 130 on a 3" rim as scrubs has would feel really good.
Offline GammaFlat
Gordon,
Where might your baffles be?
K6
K7
Suzuki GN400 - Ignition fixed!
03 KLR650 - Doesn't do anything very well but.. well.. does everything.
Offline anthony
  • ebay and i have a love hate relationship
Re: 130/90/18 or 120/90/18 new rear tire on my K1, which ?, any opinions ?
« Reply #20 on: March 28, 2011, 08:09:51 AM »
i am thinking of putting a 130 on a stock rim. has any one tried this yet
« Reply #21 on: March 28, 2011, 08:14:03 AM »
Read "333"'s post above. A 130 on a stock rim (2.15x18) is too wide. The bead won't seat safely and the ride is as 333 describes.
If your bike is later with the 2.5x17 rims, the 130 is OK.
Offline anthony
« Reply #22 on: March 28, 2011, 08:53:59 AM »
ok thanks a wreaking yard near me has new cash and carry tires for $20 it is a 130 80 18 my bike has a 18 1.85
« Reply #23 on: March 28, 2011, 08:57:31 AM »
Must be a 500/550? 130 is way too big. I was speaking of CB750.
Offline anthony
« Reply #24 on: March 28, 2011, 11:36:45 AM »
ok thank you its a 550
