Author Topic: Fried Electrical w/ 12 Volt Jumper: HELP  (Read 3369 times)
Re: Fried Electrical w/ 12 Volt Jumper: HELP
« Reply #25 on: June 15, 2009, 11:40:35 AM »
Fuses are easier to check.
Wires must be electrically conductive to carry electrical current.  You must verify continuity, or low resistance to continuity, from one end of a wire to the other.  A multimeter can measure resistance/ continuity.  A test lamp can also give an indication of continuity.  Since you can't see electron movement, test devices are used to give a visual indication of electrical capability.
You must decide which test device you wish to use.
Offline danielcgordon
  • Loving to Learn
« Reply #26 on: June 15, 2009, 11:45:22 AM »
there are the 3 fuses, all of them seemed to be intact. I'll check the wire when I get home also.
Dan
« Reply #27 on: June 15, 2009, 11:51:00 AM »
Did you "see" power going to/though them?
  • Loving to Learn
« Reply #28 on: June 15, 2009, 11:57:29 AM »
No ...I'm not sure what that looks like either. Boy this is embarrassing. But we don't know what we don't know! I was taught to look for discoloring on the glass and to make sure the inside was clean and intact?
I take it that's not sufficient.
Dan
« Reply #29 on: June 15, 2009, 12:02:26 PM »
Glass fuses can melt under the end cap where you can't see them (parted, usually form the fuse clips being oxidized and adding the heat from that resistance to the heat of the fuse.)
This is why you use test equipment to "see" electrical function.
  • Loving to Learn
« Reply #30 on: June 15, 2009, 01:40:33 PM »
Ok
Now what do I look for when reading the multimeter? Isn't that going to change from wire to wire? Also while I'm doing all of this, how about the fuses that lead from the solenoid? I believe there is 2 of them (off the top of my head)...could that create the same problem as a blown fuse from the main fuses?
Will the multimeter read wether or not the fuses are working or do I just replace them all together?
Dan
« Reply #31 on: June 15, 2009, 03:29:24 PM »
Set the multimeter to Ohms lowest scale.  Place the probe tips together.  The meter reading should be near zero, indicating little or no resistance.
Separate the probes and note the ohm reading goes very high (infinity).  Infinity is extremely resistant to current flow.   This is the stuff that makes lights not work.
When reading ohms, the meter supplies the power to measure circuits.  So, the MC battery should be disconnected, so the circuit being tested has no outside power interference.  (Old meters blow up if outside power is on the circuit under test).  Anything you place the probe tips upon will receive power from the meter (it's very small).  Place the probe tip an any wire, end to end and the meter will tell you if there is continuity through it.  The lower the resistance the better, from an electrical flow standpoint.
Note the lines on the page of the wire diagram.  Each one of those must be low resistance to make the circuit conduct power.  Each device on the bike needs two connections to the battery terminals to draw power from it.  Some devices can share these connections.  You can place a probe at each end of any wire (represented by the wire diagram), and determine its electrical current carrying ability.
There is little danger to machine or human while testing circuits with a multimeter on the ohms scale.  But, there is another way.
The meter can also read voltage if set to a voltage scale. (That's why they call it a multimeter, as it can have multiple functions depending on how the operator configures the device.)  Use the DC voltage scale for the voltage you expect to see a reading.  There are thousands of different multi-meters with slightly different control features.  Since you didn't tell me what meter you have, I can only give general guidelines.
Anyway, assuming you have selected, say, a 20 VDC scale, place the probes against each other.  Note the meter reading is zero, as the meter can detect no voltage in the circuit between the probe tips.  Now place the probe tips on the battery terminals.  Red to POS and Black to NEG.  The meter should display the battery voltage potential.  Note the reading.
With the battery connected to the bike, leave one probe on the battery neg terminal, and the red probe on each end of the fuse clips in turn.  You should read the battery voltage at both terminals.  If not there is a break in the path between the two clips.  Guess what that could be?
You can "chase" the voltage through the bike wiring using the wire diagram to show where it should be distributed.  As you follow, when voltage is not detected where it should be, go back to the last test connection where you did.  Between those two points on the bike is a failed connection, which you will have to physically fix.
Remember, there are two connections to the battery for each device that uses power on the bike, even if it uses the frame as part of that connection path.  If you find a voltage path to a lamp (for example) is intact, and the lamp still doesn't light, then there is probably that same voltage on the green side of the lamp connection (if the lamp is still good), and you follow the green path back to the battery negative until voltage is not found, go back to where last found and between those twp points is and open connection.
On the resistance scale, you can check for fuse continuity with the fuse removed from the bike.  Set the meter to measure resistance and place the probe tips at either end.  Infinaite resistance means a bad fuse, no or low resistance means the fuse is good.
During voltage checks, care must be taken with probe tip placement.  If you short circuit a wire to the frame via the probe tip, you will blow a fuse, or smoke another wire as it draws maximum current from the battery during the short circuit.  The heat and sparks generated can injure humans and the bike.  So, watch it while testing a hot bike.  Safety glasses may save your sight.
Go get 'em.
  • Loving to Learn
« Reply #32 on: June 15, 2009, 05:26:17 PM »
I borrowed one last time I used it. I'm actually going to buy one now. I'll ask a lot of questions at lowes.
Dan
