Author Topic: Won't turn over with the push button  (Read 1188 times)
Deke512
« on: May 18, 2009, 08:09:35 PM »
Hey Guys,
I have a 1981 cb650c. It won't turn over with the starter button, solenoid just clicks. When I take a screwdriver and touch the two bolts across the top of the solenoid I get sparks, starter rolls and the bike starts.  I have a brand new, fully charged battery. Head lights are full, turn signals, horn, everything electrical seems powered. I've hooked jumper cables from my car and it still just clicks.
I was searching for a new solenoid but no luck and thought that since it runs great once I "hotwire" it maybe someone may have know of another culprit.
Thanks for any help. No need to welcome me to the forum, I just haven't been here in a while and forgot my name and pass! :]
Offline new2novas
Re: Won't turn over with the push button
« Reply #1 on: May 18, 2009, 08:12:27 PM »
looks like you will most definetly need a solenoid...well maybe...try tapping it with a hammer while holding in the start button, if that gets it to go it will need a solenoid, but there is also the possibility that its not getting the proper voltage to the coil to close the contacts, see what the voltage is at the start wire
75 cb750F
Offline Spanner 1
« Reply #2 on: May 18, 2009, 08:19:09 PM »
Sounds like the 'noid is bad/sticky....if yer lucky, it comes apart with 2x phillips screws and the battery posts undone..clean/lite lube to restore start function.....
Offline new2novas
« Reply #3 on: May 18, 2009, 08:28:23 PM »
if they come apart thats a win situation....well unless its all corroded and worn
75 cb750F
Deke512
« Reply #4 on: May 18, 2009, 09:21:26 PM »
I just ran down to the garage and pulled it apart. No luck. Just clicking. And I've whacked it with a hammer several times prior!
Anyone know where I might get a solenoid?
Thanks for the help. I figured it was a bad noid.
Offline martino1972
  • and still a expert welder,period...
« Reply #5 on: May 18, 2009, 09:24:36 PM »
did you try and put a wire from your positive post from the  battery directly to the solenoid on the post where the little wire goes to..???
Marti, I want you to know, I like you an awful lot, but guys have said far less and left wearing their drinks on their shirts.
http://forums.sohc4.net/index.php?topic=36933.0  (my bobber)
Deke512
« Reply #6 on: May 18, 2009, 09:34:08 PM »
I didn't try that. I guess I thought that when I connect the two bolts on the top of the solenoid with a screwdriver, and it starts, that would rule out that the section of cable from the battery to the solenoid is faulty. But I'll give it a try.
« Reply #7 on: May 18, 2009, 09:37:11 PM »
All solenoids work the same just mightbe different shapes and wire colours
Deke512
« Reply #8 on: May 18, 2009, 09:44:08 PM »
Nope. No difference.
Offline Queeg
  • insane fuel junkie
  • OY! with the poodles allready!
    • Queegs Problems
« Reply #9 on: May 19, 2009, 02:41:25 AM »
I would check the continuity of the starter switch! Make sure its getting power. I had the same problem just to find out my switch had just turned to dust. Now I just put one under my seat.
 Also taking a wire from the positive terminal of the battery and touching the. One of the leads from the starter button would also tell you if the sylinoid is bad before you go buying a new one for no reason.
 Just my .02
guess who?
Offline new2novas
« Reply #10 on: May 19, 2009, 05:26:20 AM »
if you tried putting power to the small wire with no results, replace the solenoid.....but just for the hell of it check that when you push the button that you get 12v at the small wire at the solenoid
75 cb750F
Offline r6100mph
« Reply #11 on: May 21, 2009, 10:30:33 AM »
I had the same situation with my CB400F.  I would hit the starter button, lights would dim, but nothing on the solenoid, no click.  So i pulled the cap off the solenoid, careful not to pull the wires out, just the cap, cleaned the contact points, reinstalled.  Nothing same thing.  but this time I tracked down all the wiring, and lead me to the actual starter button.  pulled the handle bar assembly apart (not completely just enough to get cleaner in there), sprayed some electic cleaner in there, (almost like carb cleaner but for electronics)  and then everything worked!  So the button wasn't making a good enough contact to the ground inside the handle bar switch.
I would suggest checking the starter button.
