Author Topic: Stimulating the Economy (CB750 content)  (Read 6000 times)
Offline coastertrav
  • All I wanna do is racecar
« on: May 19, 2009, 11:22:47 AM »
Got a new project with my tax refund, I bought an '76 (we think) Honda CB750 from a friend. The bike is mostly complete, but after being crashed and taken apart by the PO it was abandoned in a garage completely disassembled.
The motor is intact and looks to be in good condition and has great compression, and the frame is straight with little surface rust. It needs front forks, a new front wheel, and a handful of little odds and ends here and there. My goal is to have it back together and running so I can enjoy it in the fall when it gets a little cooler down here.
Mostly looking to go the cafe/rat route with the bike, but it is going to look great when it is all back together.
« Last Edit: May 19, 2009, 01:50:32 PM by coastertrav »
Offline mystic_1
  • 1970 CB750K
Re: Stimulating the Economy (CB750 content)
« Reply #1 on: May 19, 2009, 11:35:42 AM »
Got a new project with my tax refund, I bought an '86 (we think) Honda CB750 from a friend.
Did you perhaps mean a 76?  The SOHC CB750 was not produced after 1978.
mystic_1
- John Augustus Shedd
Offline kghost
« Reply #2 on: May 19, 2009, 11:40:18 AM »
mystic_1
That will stimulate the economy  ;D
The Parts people are waiting... ;)
Stranger in a strange land
Offline coastertrav
« Reply #3 on: May 19, 2009, 01:50:05 PM »
Yeah, I definitely meant '76.
I spent today cleaning up some odds and ends, and dismantling the carbs. Ordering a rebuild kit soon...
Offline Roach Carver
« Reply #4 on: May 19, 2009, 02:03:47 PM »
f engine? k frame and tank? f front end??
Offline coastertrav
« Reply #5 on: May 19, 2009, 02:29:00 PM »
Honestly, I have no idea. It seams like I have a hodgepodge of parts.
It is a K frame, and it had dual disk brakes which would lead me to believe that it is an F front end, but I didn't think they had spoke wheels. The motor I have no clue about, and I honestly didn't know that there is a difference.
Offline kghost
« Reply #6 on: May 19, 2009, 02:41:27 PM »
Looks like a K front and a K motor someone painted black.
« Reply #7 on: May 19, 2009, 03:19:22 PM »
I am happy to defer to those with more knowledge but the first f models did in fact have spoke wheels. anyway... who cares, its a project. have fun and take a lot of pics.
Offline coastertrav
« Reply #8 on: May 19, 2009, 03:22:45 PM »
You have no idea, that is what I do.
Offline mystic_1
  • 1970 CB750K
« Reply #9 on: May 19, 2009, 03:23:40 PM »
check the crankcase directly in front of the drive sprocket, there's often damage there on these.
I see a bent rim.  Scrutinize the neck carefully, the force of that impact was transmitted up through the forks to the neck area.  Even a couple of degrees of offset will cause you problems.  Tip:  A piece of 1/2 inch conduit fits very nicely down the steering stem.  Mount the rear suspension and wheel, then install the lower triple tree and run the conduit through it, and check it hits the ground in line with the centerline of the bike
Here's a breakdown of models by serial number.  Look up your frame and engine numbers here:
http://www.sohc4.net/index.php?title=CB750K
Finally, post some closer pics of the front-end.  You may have a K front end that's been given the dual disc treatment.  Double-check the identity of your master cylinder too, it may have been changed.
Knowing what you have makes it much easier to get correct parts, and advice :)
Looks like a good starting point otherwise.  Enjoy!
mystic_1
Offline goon 1492
  • Sucka Repellant
« Reply #10 on: May 19, 2009, 03:36:13 PM »
Ooohh it has dual front discs'...I am envious, my 76 750k is half way through that but me's got too order one more fork seal...
Have fun looks like a lot of potential.
Offline coastertrav
« Reply #11 on: May 19, 2009, 03:37:26 PM »
mystic_1
Thanks man, excellent info. I'll check some of this out when I get back to the house. I'm on campus right now as the shop here has an amazing parts washer.
Offline coastertrav
« Reply #12 on: May 21, 2009, 02:52:16 PM »
mystic_1
Thanks again for the tips.
I checked out the crankcase, and all is well, no holes. I would however like to get the drive sprocket off of there, any hints?
The frame is a 76 (K6), and the motor is also a K6. The neck of the bike seems to be straight, but as soon as I get the rear tire on there I will check the alignment.
I'll get some closer pictures of the front end, and maybe you guys can help me identify it.
Offline J.Webster Designs
  • www.JWebsterDesigns.com
« Reply #13 on: May 21, 2009, 03:02:49 PM »
fellow florida guy.... I am up here in gainesville at UF. I saw the UCF plate on the miata..... there are a few of us from florida around here. i think sometime we should all get a florida meet somewhere.
VISIT OUR WEBSITE!
FOLLOW US ON SOCIAL MEDIA!
Facebook:
www.facebook.com/JWebsterDesigns
Instagram:
www.instagram.com/j.websterdesigns
« Reply #14 on: May 21, 2009, 05:04:09 PM »
to take off the front sprocket there are two bolt holding it on. pretty simple job.
Offline coastertrav
« Reply #15 on: May 21, 2009, 06:29:54 PM »
Yeah, that would be awesome.
I'll probably be driving the Miata though, as I don't see this project getting finished anytime soon, which is good. I picked up the bike because the Miata is at a point that I almost consider finished.
« Reply #16 on: May 21, 2009, 06:44:58 PM »
My cat said to ask what you smoke, & said it is definitely a K fork.
 The headlite ears look like 72,s The part of the front brake that mounts to the fork9that holds the swinging part), is either C shaped or T shaped
 c shaped is 72, T is 73 - 76.
Offline BeSeeingYou
« Reply #17 on: May 23, 2009, 10:59:47 PM »
The front fork is not from an F model.  The headlight brackets and fork gaters are a giveaway.
Offline coastertrav
« Reply #18 on: May 25, 2009, 12:41:20 PM »
Not that it really matters since it is being replaced anyways.
Offline coastertrav
« Reply #19 on: June 29, 2009, 10:14:19 PM »
So, I'm not going to lie, this project kinda got pushed aside for awhile.
But, the other day while cleaning the garage, it found new hope. I'm going to do the unthinkable and scrap the stock 750 and downgrade to a 600cc. I just am not sure about the condition of the 750, and I would hate for this bike to be full of headaches.
So here is the little 600 that I know will run...
Oh yeah, I forgot to mention, the little motor that could is out of a '07 Suzuki Gsxr. It has a full wiring harness, ecu, and less than 4k on it. I know I know, ambitious, but when you work with a bunch of guys who built a race car from the ground up, shoeing this thing in should be no problem, and I get to get rid of those god forsaken carbs.
Next to it's new home.
And from the back. I need to finish stripping the frame, but a handful of parts have already been cleaned up and primered.
« Last Edit: June 29, 2009, 10:36:08 PM by coastertrav »
Chippy569
« Reply #20 on: June 29, 2009, 10:25:18 PM »
you must be on a formula SAE team.  ;D Does your team run an F4i as well?
Do you autox your miata? if not you totally should!
Oh, the gsxr swap will definitely be interesting.
Offline coastertrav
« Reply #21 on: June 29, 2009, 10:34:44 PM »
Yeah, UCF FSAE.
We run the F4i as well, and were looking at switching to this motor but due to having a few F4i motors laying around we are just going to stick with that. Lucky for me that means we have no use for the Gsxr motor...
And I have autox'd the Miata, just not with the turbo yet. Still fixing some bugs with it.
Chippy569
« Reply #22 on: June 29, 2009, 10:39:11 PM »
hahaha awesome. I go to school up in Michigan Technological Uni and while I'm not on the FSAE team there, I did do some video production for the team.
I also autox my grand prix. it's an unlikely candidate and it does really #$%*ty but i still love doing it anyway.
Offline DollarBill
« Reply #23 on: June 30, 2009, 06:05:20 AM »
Oh....you are going to have some new headaches for sure with that transplant!  The engine may run fine but lining it all up and mounting it will be every bit as much...or more....of a headache than getting any stock cb750 motor going.  Definitely interesting though...I'll be watching this one.  Good luck.
1975 CB750F Project Yellow Jacket - CBR600rr Swinger GSXR 600 Forks
1955 BMW R25/3, 1966 Honda CA160, 1975 CB400f, 1975 CB550, 1976 CB550
« Reply #24 on: June 30, 2009, 08:53:06 AM »
Man... and you thought fixing the 750 was going to be work..LOL..
 Its gonna be more work fitting that engine, than you would have had to do to the 750..
 Have you ever opened a CB 750 up?.. one of the only engines I have seen that you can re &re every part in the engine, with 2 fists full of tools. Truly one of the easiest motors to work on..
