Author Topic: 77 78 cb750f forks  (Read 743 times)
Offline robe0531
77 78 cb750f forks
« on: May 20, 2009, 11:22:03 AM »
i was wondering if anyone call tell me if a set of forks from a 77/78 cb750f fit a 77/78cb750k
i would like to get a dual disc set up from the f model and fit it to my k
does anyone know if it will work
1978 cb750k
1968 Honda ca160
Offline doobiebro
Re: 77 78 cb750f forks
« Reply #1 on: May 20, 2009, 01:09:46 PM »
I am in the process of that swap over.  It is a easy switch if you are also changing to the Comstar wheels.  Otherwise, it takes a bit of effort.  Keep in mind that you will also need the calipers and caliper mounts from the F model.  I won't be able to report on my progress for some time yet - I am also in the process of redoing my work area in the garage.  In the meantime, there are quite a few posts in the forum regarding the dual disc set up; the search feature can find those for you.
« Reply #2 on: May 20, 2009, 02:07:05 PM »
 I did it retaining the spoke wheel. There is some work (machining) necessary. It is not a straight swap.
Offline robe0531
« Reply #3 on: May 20, 2009, 03:42:59 PM »
great thanks guys
1978 cb750k
1968 Honda ca160
