Author Topic: 350F Motor Paint Finished (PICS)  (Read 1216 times)
Offline OakBehringer
« on: May 22, 2009, 10:27:32 AM »
Finished painting the motor. Both the top and bottom ends use Duplicolor 500deg Hi-Temp Enamel. The top end is 1615 Aluminum, the bottom is 1651 Cast Coat Iron.
Process
Bottom End: Cases were not split. Clean thoroughly with simple green. Rinse. Copper wire brush all loose paint off. Rinse thoroughly with water. Wipe down with alcohol in spray bottle and a clean toothbrush to get all areas. Allow dry, applied 2 coats of paint (no primer). Ran out of paint, needed a third coat for complete coverage. It was too late to get more until the next day, so I waited a week for it to cure before applying third coat.
Top End: Head and barrels were bead blasted clean. Degreased and rinsed thoroughly. Wipe down with alcohol in spray bottle and a clean toothbrush to get all areas. Applied 3 light coats of etching primer, allowing two minutes to dry between each. Dried for at least 24 hours. Applied two light coats of paint, followed by a third medium-wet coat waiting 10 minutes between each. Process for the valve cover was the same, except I cleaned the old paint off with carb cleaner instead of having it bead blasted.
I had to stack on the top end on take a pic. Can't wait to put it back together for real and fire her up.
The Cast Coat Iron will match the pinstripe in my tank. It looks PHENOMENAL, doesn't it!?
1974 350 Four - SOLD
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
Re: 350F Motor Paint Finished (PICS)
« Reply #1 on: May 22, 2009, 11:18:36 AM »
Thats some serious bling right there. :o
Nice looking work, OB!
i'll go clean my dirty 350F now  :-[
Offline manjisann
« Reply #2 on: May 22, 2009, 11:32:44 AM »
Very Nice!!
Brandon
1980 CB650 Custom
