Author Topic: Rubber coated steel base gasket  (Read 1152 times)
« on: May 22, 2009, 05:01:47 PM »
Anyone tried one of these yet? I was planning on a thin copper base gasket for an engine in the works, but like the sound of this.
It would be nice to know how they hold up on disassembly especially. Probably not good....advantage copper.
Reasonably priced though.
Re: Rubber coated steel base gasket
« Reply #1 on: May 22, 2009, 05:49:23 PM »
I've used the Cometic's Brent and have had good luck with them. The last one I used was a .010 for my FJ
« Reply #2 on: May 22, 2009, 07:49:10 PM »
Thanks Mike, I may go this route. It should seal well, I just wonder whether or not the rubber will stick to the mating surfaces on tear down.
« Reply #3 on: May 22, 2009, 08:00:30 PM »
  It may stick a little but I've torn them down....it only takes a green Scotchpad and brake cleaner to remove the residue
« Reply #4 on: May 22, 2009, 08:05:21 PM »
Good deal, they're available in several different thicknesses so that's good too.
By the way Mike, check your e-mail if you please.
Offline new2novas
« Reply #5 on: May 22, 2009, 08:11:35 PM »
you can never go wrong with cometics, for any application as far as i'm concerned....
75 cb750F
Offline mark
« Reply #6 on: May 23, 2009, 07:26:40 AM »
maybe the spam folder too.....
F you mark...... F you.
