Well. I have been doing the wiring the last few days. I started with the Electronic ignition, and then the regulator and rectifier. Then it was on to the Ignition/key switch, coils, blinkers, headlight, kill switch and the speedo/tach with dummy lights. I am almost there!
After that i have to put the oil pan on to button up the motor and then do all the valves and timing stuff. Oh! and put oil in.
Not trying to start a debate but should i use semi synthetic? What are you guys that build race bikes putting in your fresh motors?
Built a coil mounting plate.
This is the mesh expandable cable wrap im using. I like it, looks pretty clean.
Lots of wires. The Key is an On/OFF/ACC/START switch so it has a temporary switch to use for the starter like a car.
Everything should tuck nicely above the coil.
Wire diagrams, Honda manual, Dyna 2000 and Acewell speedo.
OH and now that i think about it i still have to pull wire for my tail light and the switch for the brake. Im going to use a taillight from custom dynamics. Going to mount it under the tail in the back.
49011
